The barometric equation gives the pressure dependence of a perfect gas in a gravitational potential. In particular
$$ P(h) = P_0e^{-\frac{mgh}{k_BT}} $$
where $m$ is the mass of molecules and $T$ the temperature of the gas.
What would happen if we had an atmosphere composed of different species? I would expect it to be layered with heavier gases at the bottom and lighter ones on top with transitions between gases looking something like a $tanh(h)$. Can this be derived from statistical mechanics relatively easily?
Andrea
  • 743
If we suppose ideal gases, remember that the pressure of an ideal gas depends on the number of molecules, however, it has an influence on the distribution of the gas with a gravitational potential. However, you can substitute in your equation the molar mass with the average molar mass. This molar mass $M$ can be found in the following equation, which you can find in Wikipedia: $$M = \sum _i x_i M_i$$ where $x_i$ is the mole fraction of the $i_{th}$ compound and $M_i$ the molecular mass of that $i_{th}$ compound. So, for example, air gives us a molar mass of $28.7 g/mol$. Substituting the formula you gave will give the result you wanted.
