Why is electric field zero in a wire with 0 resistance given nonzero voltage and infinite charge inside a battery?
It is true that for a wire with $0$ resistance there will uniform voltage across the wire. But comparing with an electron in an empty space it seems to be different. Imagine in a space I reference $0$ potential energy very far away from electron($e_o$). Now if we insert an electron in the system and place it near the electron let's call it $e_i$ then shouldn't $e_i$ lose potential as it is freed? It is counterintuitive that if there is an ideal wire like this then there is no change in potential energy thus no potential difference. And for ohm's law $V/R=I$ for resistance equal $0$ current is undefined so what is happening in conductor? Is electron even moving? I think there is also another way to reason which is equipotential surface but it is not clear to me how with $0$ resistance the wire just become equipotential.
