-1
How can I prove that $$\frac{\partial(T \ln Z)}{\partial T}=\ln \Omega,$$ without using the relation $S=k\ln Ω$?
where $Z$ is the Partition Function, $T$ is the Absolute Temperature, $Ω$ is the Statistical Weight of a Macro-state, $S$ is the Entropy of the system.
For the actual problem, I have provided this below Image file
Lusypher
  • 197
You need to be a bit more careful in how you reframe the problem, because 2.64b is not making an assumption about the ensemble, but your equation does (implicitly, equal a priori probabilities).
The general statement,
$$\frac{S}{k_B} = \frac{\partial}{\partial T}\left ( T\ln Z \right ) \tag{1}$$
Is true. Apply the partition function from the canonical ensemble:
$$Z(T)=\sum_i e^{-E_i/k_B T}$$
The partial derivative of temperature on $Z$ will not be affected by the limits of integration on the phase space, so it is fine to bring the derivative inside the sum.
Recall the Helmholtz Free Energy, $$F=U-TS$$
$F$ has a relationship to $Z$,
$$\ln Z= \frac{-F}{k_B T} \tag{2}$$
Putting all of this together gives $(1)$.
Also, you can use information from the Legendre transform to jump straight to the answer:
$$-F(V,T)+U(V,S)=TS$$
Therefore, at constant volume,
$$\frac{\partial F}{\partial T}=-S$$
It's easy to see from here how we get $(1)$ again.
michael b
  • 832
