How can satellites change direction without any medium in space? How do spaceships move in space if there is no medium?
How does Newton's third law of motion work in space?
How satellites can change direction without any medium in space? How do spaceships move in space if there is no medium?
It works by the principle of conservation of (linear) momentum which is derived directly from the third Newton's law of motion. Effectively, the rocket ejects fuel at high velocity in the opposite direction to where it wants to go. Remember that the momentum is a vector quantity
$$\vec{p} = m \vec{v}$$
Conservation of momentum is applied to the system of rocket and fuel
$$\vec{p}_\text{rocket} + \vec{p}_\text{fuel} = \text{const.}$$
Simply put, velocity of the center of mass of the system of rocket and fuel stays constant. You can try this principle at home with roller skates and some (modestly) heavy object that you can throw. Throw the object in front of yourself while standing at rest in roller skates and watch what happens - in addition to breaking your parents furniture, you will start moving backwards due to the conservation of momentum. Roller skates are used to minimize friction with the surface, and the object you throw is like the fuel in the rocket.
See the following Wiki article for maths: “Variable-mass system”
Marko Gulin
  • 5,250
If you are in space, floating at zero g, and you throw a heavy ball in one direction, you'll float in the opposite direction (action/reaction, conservation of momentum). You don't need any medium. Once you're moving, you don't need to do anything to keep moving (law of inertia). If you want to change direction or speed (or if you want to stop), you need to throw another ball (or a couple of them).
Now, instead of throwing balls, make a tube with an open end (maybe attach a nozzle), and eject a whole bunch of particles (like, gazillions of them - a fuel of some sort) at high speed. Now you have something like a thruster, or if you really engineer it up, a rocket engine. Take one big engine as your primary propulsion, and arrange smaller thrusters around the rocket so that you can change direction, and there you go.
You do not need a medium to push against. Several principles are used to change direction of satellites.
  • Newton's third law is used by thrusters and cold gas engines. Every action (particles leave thruster of the satellite) has a reaction. E.g. The satellite moves the opposite direction. $\vec p_r=-\vec p_a = m_a \cdot \vec v_a$ follows conservation of momentum. We want to save fuel. Hence we want to reduce mass $m_a$. As a result the fuel has to be leave the satellite a high velocity by e.g. combustion or acceleration by electric force.
  • Magnetic torquers leverage Lorentz force of a magnetic field of e.g. the Earth. An electric coil creates a magnetic moment $\vec m$. The interaction with Earth's magnetic field of $T_e\approx 50\,\mu T$. A torque $\tau = \vec m \times\vec B $ is created.
  • Reaction wheels are as well not based on Newton's law and stabilise the orientation of the satellite. The physical principle is a gyroscope (spinner).
