Searching for an implementation (that helps me to understand how $SO(3)$ and $SU(2)$ relate to each other) I came across this interesting question Visual interpretation, on the Bloch sphere, when Hadamard gate is applied twice where qutip is utilized. However my question is more fundamental.
Using qutip too, I implemented a rotation of a Qubit on a Bloch Sphere using $SO(3)$ as follows:
import qutip as qt
from qutip.qip.operations import rx
import numpy as np
def to_spherical(state): r0 = np.abs(state[0]) ϕ0 = np.angle(state[0]) r1 = np.abs(state[1]) ϕ1 = np.angle(state[1]) r = np.sqrt(r0 ** 2 + r1 ** 2) θ = 2 * np.arccos(r0 / r) ϕ = ϕ1 - ϕ0 return [r, θ, ϕ]
def to_cartesian(polar): r = polar[0] θ = polar[1] ϕ = polar[2] x = r * np.sin(θ) * np.cos(ϕ) y = r * np.sin(θ) * np.sin(ϕ) z = r * np.cos(θ) return [x, y, z]
def rn_so3(state, theta, phi, delta): rn_mat = qt.Qobj( [[np.cos(delta/2) - (0+1j)np.cos(theta)np.sin(delta/2), -(0+1j)np.exp(-(0+1j)phi)np.sin(delta/2)np.sin(theta)], [-(0+1j)np.exp((0+1j)phi)np.sin(delta/2)np.sin(theta), np.cos(delta/2) + (0+1j)np.cos(theta)np.sin(delta/2)]] ) r_state = (rn_matstate)(rn_mat*state).dag() return(r_state)
b = qt.Bloch() b.clear() b.make_sphere()
states = [] points = []
alpha = 1/np.sqrt(2) beta = 1/np.sqrt(2) s = np.array([alpha,beta]) state = qt.Qobj(s) states.append(state)
Ψ = [complex(alpha, 0), complex(beta, 0)] polar = to_spherical(Ψ) pnt = to_cartesian(polar) points.append(pnt)
rotated = state for i in range(0,10): rotated = rn_so3(rotated, 0.4, 0.3, 0.2) pnt = [(qt.sigmax()rotated).tr(), (qt.sigmay()rotated).tr(), (qt.sigmaz()*rotated).tr()] states.append(rotated) points.append(pnt)
b.add_states(states) np_points = np.array(points) b.add_points([np_points[:,0], np_points[:,1], np_points[:,2]]) b.show()
The corresponding output looks as follows:
My question: Can I achieve the same output using the $SU(2)$ group and coordinate transformations?
I found also the formula for the rotation around an axis on the Bloch Sphere with an angle $\theta$ that looks as follows:
$$R_A(\theta)=\cos\frac{\theta}{2}\sigma_I-i\cdot\sin\frac{\theta}{2}(x_A\sigma_x+y_A\sigma_y+z_A\sigma_z)$$ which I tried to implement too but didn't output the desired rotation.
My trial looks as follows and I am trying to refer to this document "Lecture notes: Qubit representations and rotations":
def rn_su2(θ, ϕ):
    return (np.sin(θ)*np.cos(ϕ)*qt.sigmax() + np.sin(θ)*np.sin(ϕ)*qt.sigmay() + np.cos(θ)*qt.sigmaz())
rotated = state for i in range(0,10): # # Here seems to go something wrong # rotated = rn_su2(0.2i, 0.3i) states.append(rotated)
#polar = to_spherical(rotated)
#pnt = to_cartesian(polar)
points.append(pnt)
Here I have some fundamental error and would appreciate any help or hint.
Update 2022-03-19: I implemented the $SU(2)$ rotation according the useful hint in the comment. It looks better, but unfortunatelly the state lies not on the Bloch Sphere anymore:
def rn_su2(θ, state, nx, ny, nz):
    Ψ = [state.data[0,0], state.data[1,0]]
    arr = to_spherical(Ψ)
    s_θ = arr[1]
    s_ϕ = arr[2]
    M_q = np.sin(s_θ)*np.cos(s_ϕ)*qt.sigmax() + np.sin(s_θ)*np.sin(s_ϕ)*qt.sigmay() + np.cos(s_θ)*qt.sigmaz()
    U_n = qt.qeye(2)*np.cos(θ/2) -1j*(nx*qt.sigmax()+ny*qt.sigmay()+nz*qt.sigmaz())*np.sin(θ/2)
    r_state = U_n*M_q*U_n.dag()
    return r_state
Update 2022-03-20: After fixing the $SU(2)$ rotations code it looks good and correct. Now I'm just struggling with the actual question: what angles do I need to use so that both plots (vertex sequences) look the same? In the $SO(3)$ implementation case I used rotated = rn_so3(rotated, 0.4, 0.3, 0.2) and to get an almost same looking picture, by trial and error, I obtained for the $SU(2)$ implementation:
rotated = rn_su2(0.05, rotated, 1, 0, 0)
rotated = rn_su2(0.02, rotated, 0, 1, 0)
rotated = rn_su2(0.2, rotated, 0, 0, 1)
The comparative figures are as follows:
