I’m trying to work through the Ozma problem and the Wu experiment to get a better handle on parity and I’m being tripped up by something which is almost certainly trivial.
I can explain negative charge to aliens by saying heat up a gas, the stuff it emits is negatively charged.
I can say run a solenoid vertically with very cold Cobalt-60 in the middle. Run a current and define the current flow as being from +ve to ve- charge.
Here is my problem - to say which direction the Cobalt-60 spin will be oriented needs a sense of magnetic field orientation which requires the right hand rule and a consensus about which direction right is.
What do I say to the aliens about placing gamma ray and electron detectors to help them understand left from right? Is it - you’ll see more electrons emitted in the opposite direction of the current? If so how are they getting left/right out of it?
