-1
This is a common statement that the force between two charges changes when the intervening medium is changed however the gravitational force remains the same. But I have some problem with this.
When two charges are kept in a medium, their electric field polarises the medium and this in turn affects the strength of the electric field and hence the force on the other charge changes. But isn't this new force a result of the intervening particles of the medium ? I think this new force is the net resultant of all the forces due to those polarised particles.
"So does the force between them change ? Or is it the net force on each charge which has changed ?"
And also when two bodies are kept in a medium , the particles of the medium also exert gravitational force on the two bodies , so shouldn't we say that the gravitational force between them has changed ? (And hence define something like gravitational permittivity !!)
Ankit
  • 8,944
  • 32
  • 90
Yes.
Yes.
It is the net force on each charge that changes, due to the polarization of the matter in between.
The matter between two particles contributes to the net gravitational force between those particles. However, the situation is somewhat different from that of electric forces.
Ordinary, electrically neutral, matter is neutral because it has a balance of positive and negative charges. However, ordinary matter is not "gravitationally neutral". There is no balance in ordinary matter between "positive" and "negative" mass. Thus, the gravitational effect of matter upon a test mass does not depend upon any "gravitational polarization", while the electrical effect of electrically neutral matter upon a test charge does depend upon electrical polarization.
So, when we place an mass between two particles, the gravitational force is increased, but we would expect that merely because the matter has mass.
When we place an electrically neutral dielectric or a conductor between two charged particles, the electric force is increased, but it seems to need explaining, because the dielectric or conductor is electrically neutral. And, we explain the effect by polarization.
