I'm trying to find trying to find the Lagrangian and Hamiltonian for a particle in a non-inertial frame, but when I try to do so, I always get a quadratic term, which textbooks like Landau & Lifshitz vol. 1 ignore for a reason I will specify later. Here's what I have:
The Lagrangian in the inertial frame is $$L = \frac12 m \mathbf{\dot{r}}^2 - U(\mathbf{r})$$ This means, that in the tranformation to a non-inertial frame, where $\mathbf{v}=\mathbf{v'}+\mathbf{V}(t)$, then we have \begin{align} L &=\frac12 m (\mathbf{\dot{r'}}+\mathbf{V})^2 - U(\mathbf{r'})\\ &=\frac12 m \mathbf{\dot{r'}}^2 + \frac12 m\mathbf{V}^2 + m\mathbf{\dot{r'}}\cdot\mathbf{V} - U(\mathbf{r'}) \end{align} Landau & Lifshitz says the following though:
"$\mathbf{V}^2(t)$ is a given function of time, and can be written as the total derivative with respect to $t$ of some other function; the [$\frac12 m \mathbf{V}^2$] term can therefore be omitted."
Could someone explain this logic to me? I don't see the connection.
Pocher
  • 57
  1. It is important that the velocity ${\rm V}(t)$ of the reference frame is a given/prescribed external parameter (as opposed to an active dynamical variable) of the theory. We can then consistently view $\frac{m}{2}{\bf V}^2(t)$ as a total time-derivative. See also e.g. this related Phys.SE post.
  2. L&L are next relying on the fact that the Euler-Lagrange (EL) equations are not changed if the Lagrangian is changed by a total time derivative, cf. e.g. this Phys.SE post.
... in the transformation to a non-inertial frame... we have \begin{align} L &=\frac12 m \mathbf{\dot{r'}}^2 + \frac12 m\mathbf{V}^2 + m\mathbf{\dot{r'}}\cdot\mathbf{V} - U(\mathbf{r'}) \end{align} Landau & Lifshitz says the following though:
In general, if $F=F(q,t)$, we have $$ \dot F = \frac{dF}{dt} = \frac{\partial F}{\partial q}\dot q + \frac{\partial F}{\partial t}\;, $$ which means that $$ \frac{\partial \dot F}{\partial \dot q} = \frac{\partial F}{\partial q}\;. $$
If we have two Lagrangians that differ by the total time derivative of F: $$ \bar L = L + \frac{dF}{dt}\;, $$ then the equations of motion derived from $\bar L$ and $L$ are the same, since $$ \frac{\partial \bar L}{\partial \dot q} = \frac{\partial L}{\partial \dot q} + \frac{\partial \dot F}{\partial \dot q} = \frac{\partial L}{\partial \dot q} + \frac{\partial F}{\partial q} $$ and $$ \frac{\partial \bar L}{\partial q} = \frac{\partial L}{\partial q} + \frac{\partial \dot F}{\partial q} = \frac{\partial L}{\partial q} + \frac{d}{dt}\frac{\partial F}{\partial q}\;. $$
Such that: $$ \frac{\partial \bar L}{\partial q} - \frac{d}{dt}\frac{\partial \bar L}{\partial \dot q} = \frac{\partial L}{\partial q} + \frac{d}{dt}\frac{\partial F}{\partial q} - \frac{d}{dt}\left(\frac{\partial L}{\partial \dot q} + \frac{\partial F}{\partial q}\right) $$ $$ = \frac{\partial L}{\partial q} - \frac{d}{dt}\frac{\partial L}{\partial \dot q} + \frac{d}{dt}\frac{\partial F}{\partial q} - \frac{d}{dt}\frac{\partial F}{\partial q} $$ $$ = \frac{\partial L}{\partial q} - \frac{d}{dt}\frac{\partial L}{\partial \dot q} $$
For the more specific case of interest here, $F=F(t)$, is only a function of time (not a function of $q$ and $t$): $$ F(t) = \int^t dt' \frac{m}{2}V^2(t') $$
The relation $$ \frac{\partial \dot F}{\partial \dot q}=\frac{\partial F}{\partial q} $$ still holds, but is trivial in this case, since both sides of the equation are zero. Nevertheless, since the equation still hold the equations of motion derived from $\bar L$ and $L$ are the same.
Even more specifically, for the case of interest here (note, I write q instead of OP's r', and I write $\bar L$ instead of OP's $L$): $$ \bar L = L + \frac{dF}{dt} =\frac12 m \mathbf{\dot{q}}^2 + m\mathbf{\dot{q}}\cdot\mathbf{V} - U(\mathbf{q}) + \frac12 m\mathbf{V}^2 $$ $$ L = \frac12 m \mathbf{\dot{q}}^2 + m\mathbf{\dot{q}}\cdot\mathbf{V} - U(\mathbf{q}) $$
$$ \frac{\partial \bar L}{\partial \mathbf{q}} = -\nabla U $$ $$ \frac{\partial L}{\partial \mathbf{q}} = -\nabla U $$
$$ \frac{\partial \bar L}{\partial \mathbf{\dot q}} = m \mathbf{\dot q} + m\mathbf{V} $$ $$ \frac{\partial L}{\partial \mathbf{\dot q}} = m \mathbf{\dot q} + m\mathbf{V} $$
So, regardless of whether you work with $L$ or $\bar L$ you end up with the equations of motion: $$ m \mathbf{\ddot q} + m\mathbf{\dot V} = -\nabla U\;. $$
hft
  • 27,235
