In mechanics we perform the Legendre transform to go from the Lagrangian $L(q, \dot{q})$ to the Hamiltonian $H(q, p)$. This seems to be describing the same physical system. $L$ and $H$ both describe an object(s) moving under certain constraints. In contrast, in stat mech we transform internal energy $U(S,V)$ to enthalpy $H(S, P)$. This seems to be describing different physical systems. $U(S,V)$ holds pressure constant. An example system would be a closed rigid container. On the other hand $H(S,P)$ holds volume constant. An example system would be a beaker in a lab. Is this understanding correct and if so, why does Legendre transform describe 2 views on the same physical system in mechanics but 2 different physical systems in stat mech?
Kevin
  • 131
