16
We had a couple of examples where we were supposed to calculate the Canonical Transformation (CT), but we never actually talked about a condition that decides whether a transformation is a canonical one or not.
Let me give you an example: We had the transformation: $$P=q \cdot \cot(p), \qquad Q=\ln \left(\frac{\sin(p)}{q}\right).$$ How do I see whether this transformation is a canonical one or not?
You don't have to carry out the full calculation, but maybe you can give me a hint what I need to show here?
Xin Wang
  • 1,968
There are three easy tests to check if a transformation is canonical. Note that some multiplicative constants might pop up in certain textbooks, depending on the exact definition of canonical transformation.
Notation
Let $x = (p, q)$ be the $2n$ variables, and the transformed variables be $\tilde{x}(x) = (\tilde{p}(p, q), \tilde{q}(p, q))$.
The method of the symplectic jacobian
Let $J = \partial \tilde{x} /\partial x $ be the Jacobian matrix of the transformation. Moreover, let $\mathbb{E}$ be a $2n \times 2n$ block matrix $$ \mathbb{E} = \begin{pmatrix} 0 & 1 \\ -1 & 0 \end{pmatrix} $$
Then the transformation is canonical if and only if
$$ J\mathbb{E}J^T = \mathbb{E} $$
The method of Poisson brackets
The transformation is canonical if and only if the fundamental Poisson brackets are preserved
$$ \{\tilde{p}_i, \tilde{p}_j\} = 0 \qquad \{\tilde{q}_i, \tilde{q}_j\} = 0 \qquad \{\tilde{q}_i, \tilde{p}_j\} = \delta_{ij} $$
The method of the Liouville differential form
This is somewhat less practical, but I include it for completeness. The transformation is canonical if and only if the differential form $\sum_i p_i \mathrm{d}q_i - \sum_i \tilde{p}_i \mathrm{d}\tilde{q}_i$ is closed.
Enucatl
  • 639
Hint: Poisson Brackets are canonical invariants, this is
$$\{F,G\}_{q,p}=\{F,G\}_{Q,P} $$
J L
  • 2,947
Another way (a practical shortcut) is to try to find a generating function. In this case, we shall use $F_3(Q, p)$ since $Q$ and $p$ appear to be more basic variable. The original equations are equivalent to \begin{align} P &= q \, \cot p \tag{1} \\ q &= e^{-Q} \, \sin p. \tag{2} \end{align} Eq. (1) is equivalent to \begin{align} P = e^{-Q} \, \cos p. \tag{3} \end{align}
Now from Eqs. (2) and (3), we can readily verify that $F_3(Q, p) = e^{-Q} \cos p$ satisfies \begin{align} P = - \frac{ \partial F_3 }{ \partial Q }, \tag{4} \\ q = - \frac{ \partial F_3 }{ \partial p }. \tag{5} \end{align} This means for the given transformation is generated by this $F_3(Q, p)$, and hence is canonical.
Note that the possible functional form of $F_3(Q, p)$ can be deduced from a trial-and-error approach. In this case, we actually integrated Eq. (4), $$ F_3 = -\int P \, dQ = -\int e^{-Q} \cos p \, dQ = e^{-Q} \cos p, $$ and then verified it satisfied Eq. (5).
hbp
  • 174
The answer by Enucatl is satisfying enough. However, in the example $$P=q \cot(p),$$ $$Q=\ln \left (\frac{\sin(p)}{q}\right),$$ given in the question, it seems there is dimensional mismatching.
The argument inside $\cot$ must be some $[p/(p_o)]$ where $p_o$ has dimensions of momentum and the argument of the logarithm must be $$q_o \frac{\sin(p/p'_o)}{q},$$ $p'_o$ neednot be equal to $p_o$. Even if P and Q do not have dimensions of momentum and length respectively it may not matter (well known as per any general case of a canonical transformation).
I am curious to know if the operations for dimensional matching implied (like the fashionable(which I don't like) way of certain books taking $c=1$ and calling the relativistic energy of a free particle $E =(m^2+p^2)^{1/2}$ instead of $ E = (m^2 c^4+p^2c^2)^{1/2}$ etc.).
glS
  • 15,488
  • 42
  • 114
