My question is quite general, but it is inspired by P&S and especially Chapter 12. In Chapter 12 they start with the generating functional, in which the functional integral is over the Fourier transform of the field configuration $\phi(k)$ $$Z[J]=\bigg(\prod_k\int d\phi(k)\bigg)e^{i\int[\mathcal{L}+J\phi]}.\tag{12.1}$$
  1. First, I would like to clear a small misunderstanding: the exponent of the exponential contains an integral but no integration measure. Integration over the momentum space is implied right? Does it even matter?
  2. And then, my real question is how do I transform from a functional integral over the field to a functional integral over the fourier transform of the field? What is going on in that functional integration measure and how do I go from $\mathcal{D}\phi(x)$ to $\mathcal{D}\phi(k)$ and vice versa??
I have read P&S and Srednicki, also did some google search, but I couldn't find anything satisfactorily rigorous.
schris38
  • 4,409
From context, yes I would interpret the measure as an integral over momentum space. I am only speculating, but perhaps they did not include the measure to avoid confusion between the $k$ appearing in the path integral measure, and the $k$ that would appear if they wrote the measure in the action explicitly.
And then, my real question is how do I transform from a functional integral over the field to a functional integral over the fourier transform of the field? What is going on in that functional integration measure and how do I go from () to () and vice versa??
Note the integral equation \begin{equation} \tilde{\phi}(k) = \int d^4 x e^{i k x} \phi(x) \end{equation} has the form of a matrix equation \begin{equation} \tilde{\phi}_n = U_{n j} \phi_j \end{equation} if we interpret the sum over $j$ as an integral, and where $U_{n j} = e^{i k_n x_j}$ is a unitary matrix.
Therefore, when doing a change of variables in the integration measure from from $\prod_k d \tilde{\phi}(k)$ to $\prod_x d \phi(x)$, we pick up a trivial Jacobian factor $\det U = 1$.
It actually doesn't even really matter that $U$ is unitary; the key point is that $U$ is independent of the field (in other words, we've done a linear change of variables). This is because in the end, we are almost always interested in ratios of partition functions, like $Z[J]/Z[0]$, so an overall field-independent constant will drop out of the final answer.
Putting this together, we can equate the path integrals written in momentum space and real space, since they only differ by a linear change of variables \begin{equation} \left(\prod_k \int d \tilde{\phi}_k \right) e^{i \int d^4 k' \mathcal{L}} = \left(\prod_x \int d \phi_x \right) e^{i \int d^4 x' \mathcal{L}} \end{equation} The momentum space representation is usually more useful for perturbation theory.
Andrew
  • 58,167
