If a star passes near another star will that star feel gravitational influence immediately or with a delay? Assuming that the distance is a large number and the stars are very massive?
The gravitational field of an object generally moves as though rigidly attached to the object. It doesn't lag behind, so its influence on other objects is similar to a Newtonian field that always updates instantly. There isn't the light-speed delay that you might expect.
This is actually required by the principle of relativity. If an ordinary solid object is at rest in a vacuum and you push a small part of it to start it moving, that part moves before the rest of it at first, but over time the rest of the object catches up; it doesn't permanently lag behind. It can't, because an object in motion is the same as an object at rest, so there is no behind. Only if a part of the object moves in a complicated way that isn't "expected" by the rest of the object do you get update delays. Gravitational and electromagnetic fields work in a similar way.
benrg
  • 29,129
Gravitational fields propagate in the vacuum with the speed of light according to the equations $\;\;\left(\frac{\partial^{2}}{\partial x^{2}}-\frac{\partial^{2}}{\partial t^{2}}\right)h_{i}^{k}=0\;\; $ (in one dimension to simplify) exactly like electromagnetic field *.
By analogy we can use the Retarded potential **.
(*) Far from the bodies the field is weak, which implies that the space-time metric is almost Galilean, and one can thus use a reference frame in which the components of the metric tensor are almost equal to the Galilean values $\;\;g_{ij}=g_{ij}^{(0)}+h_{ij}\;\;\;\;,g_{00}^{(0)}=1\;\;,g_{0\alpha}^{(0)}=0\;\;, g_{\alpha\beta}^{(0)}=-\delta_{\alpha\beta}$
(**) The retarded potential in linearized general relativity .
The Tiler
  • 1,548
