In a classic Georgi review of EFT, I have read the following quote
The result of eliminating heavy particles is inevitably a nonrenormalizable theory, in which the nontrivial effects of the heavy particles appear in interactions with dimension higher than four. In the full theory, these effects are included in the nonlocal interactions obtained by integrating out the heavy particles. These interactions, because of their nonlocal nature, get cut off for energies large compared to the heavy particle masses. However, in the effective theory, we replace the nonlocal interactions from virtual heavy particle exchange with a set of local interactions, constructed to give the same physics at low energies. In the process, we have modified the high energy behavior of the theory, so that the effective theory is only a valid description of the physics at energies below the masses of the heavy particles. Thus the domain of utility of an effective theory is necessarily bounded from above in energy scale.
Why are the new interactions, obtained in the EFT by integrating out the heavy fields, nonlocal? I can't see this as a direct consequence of the nonrenormalizability of the interaction or of the fact that it depends on the exchanged momentum.
I do understand that interactions mediated by massive particles are shortrange because the corresponding effective potential is damped by a real exponential term -- but don't know if this has anything to do with my doubt and think that perhaps I'm confusing the concepts of 'local' and 'short range'.
Then, in the phrase
I believe that Georgi is talking about the fact that we expand that new effective interaction in powers of $\left( \frac{p^2}{M^2}\right)$.
Why is the expanded perturbative interaction, now, local?
GaloisFan
  • 1,812
Suppose we start with a UV theory \begin{equation} \mathcal{L} = -\frac{1}{2} (\partial \phi)^2 - \frac{1}{2} (\partial \psi)^2 - \frac{1}{2} M^2 \phi^2 + g \phi \psi^2 \end{equation} where $\phi$ is a heavy field with mass $M$, and $\psi$ is a light field (taken to be massless for simplicity).
We integrate out $\phi$ by solving it's equation of motion. In other words, we make the following replacement in the action \begin{equation} \phi = \frac{g \psi^2}{-\square + M^2} \end{equation} The notation $(\square + M^2)^{-1}$ means to use an appropriate Green's function for the operator $\square + M^2$. You can think of it in momentum space, if you like.
Note that the expression for $\phi$ is non-local. This is because integrating $g\psi^2$ against the Green's function involves an integral over space and time. The integral is non-local, since it involves more than one spacetime point.
Plugging this back into the action, we get a non-local Lagrangian for $\psi$ \begin{equation} \mathcal{L} = - \frac{1}{2} (\partial \psi)^2 + \frac{1}{2}\psi^2 \frac{g^2 }{-\square + M^2}\psi^2 \end{equation} At this stage, the Lagrangian is non-local, but the physics is completely equivalent to the original Lagrangian.
Now we Taylor expand \begin{equation} \frac{1}{-\square + M^2} = \frac{1}{M^2} + \frac{\square}{M^4} + \cdots \end{equation} If we truncate the Taylor expansion, we are left with a local expression (local since there are only a finite number of derivatives and no integrations). The resulting effective theory involves only the light field $\psi$, is local, but is only valid while the Taylor expansion can be trusted, that is, for energies much less than $M$ (when the heavy field cannot be directly produced) \begin{equation} \mathcal{L}_{\rm eff} = -\frac{1}{2} (\partial \psi)^2 + \frac{g^2}{2 M^2} \psi^4+ \frac{g^2}{2 M^4} \psi^2 \square \psi^2 \end{equation} We could include additional terms, if we wanted a higher level of precision.
Andrew
  • 58,167
That's a good question.
The Wilsonian effective action (WEA) $$\begin{align} \exp&\left\{ -\frac{1}{\hbar}W_c[J^H,\phi_L] \right\}\cr ~:=~~~&\int \! {\cal D}\frac{\phi_H}{\sqrt{\hbar}}~\exp\left\{ \frac{1}{\hbar} \left(-S[\phi_L+\phi_H]+J^H_k \phi_H^k\right)\right\} \end{align}$$ is defined by integrating out heavy/high modes $\phi^k_H$ and leaving the light/low modes $\phi^k_L$. Here $S$ denotes the action of the underlying UV theory. It may depend on a UV cut-off $\Lambda_H\gg \Lambda_L\equiv\Lambda$. The UV action $S$ is conventionally assumed to be local at distances $r\gg \Lambda_H^{-1}$, i.e. it is local for all practical purposes, and we will for simplicity view it as local for the remainder of this answer.
Moreover, here $J^H_k$ denote sources for the heavy modes. They are included for generating purposes and are usually put to zero at the end of the calculation.
The WEA is the generator of connected Feynman diagrams made from heavy propagators $G_H$, local interactions in $S$, and background $J^H$, $\phi_L$.
Due to the bi-local propagators, the WEA is non-local by construction; however the non-locality is exponentially suppressed, cf. Ref. [1,2,3,4]. E.g. if the heavy modes have mass $M$, then propagators take the form $$G_H({\bf r})~=~(-\Box+M^2)^{-1}\delta^{d}({\bf r})~\sim~e^{-Mr}\quad{\rm for}\quad r~\equiv~|{\bf r}|~\gg~ M^{-1}.$$
The WEA is only meant to be probed at low momenta $p\sim\partial\ll\Lambda\lesssim M$ below the scale $\Lambda$; equivalently, at IR distances $r\gg M^{-1}$. We will assume it is possible in this region to adequately approximate the WEA by an infinite series of mono-local higher-order derivative terms, perturbatively in $\partial/M\ll 1$.
For tree diagrams in the WEA, we can be more explicit, since there are no loop-momenta. If we impose low momenta in the background $J^H$, $\phi_L$, then the momentum conservation forces low momenta to run through the heavy propagators. In that case, we can expand the propagator perturbatively in $M^{-1}$, $$G_H({\bf r})~=~(-\Box+M^2)^{-1}\delta^{d}({\bf r})~=~\frac{1}{M^2}\sum_{n\in\mathbb{N}_0}\left(\frac{\Box}{M^2} \right)^n\delta^{d}({\bf r}).$$
The upshot is that we can rewrite the WEA perturbatively in $M^{-1}$ to only consist of mono-local terms, i.e. we can define a Wilsonian effective Lagrangian density (WELD). Since the number of spacetime derivatives is unbounded, the WELD is by definition non-local, cf. e.g. this Phys.SE post.
References:
  1. D. Skinner: QFT II, the RG; p. 59.
  2. T.J. Hollowood, 6 Lectures on QFT, RG and SUSY, arXiv:0909.0859; p. 15.
  3. J. McGreevy, QFT Lecture notes, spring 2015; p. 16 + p. 73.
  4. S. Weinberg, Quantum Theory of Fields, Vol. 1, 1995; p. 522.
