In searching for images of spinning black holes, one finds a discrepancy. In many cases, the outer event horizon is spherical, with a simple formula for the radius. For example, Forbes and many other sites describe the outer event horizon as spherical with radius: $r = m + \sqrt{m^2 - a^2}$ with m being $GM/c^2$ and $a$ being the angular momentum.
Yet wikipedia (and many other sites) draw the event horizon as asymmetric and bulging at the equator. That particular link also shows the ergoshere as extending out beyond $2GM/c^2$.
If the difference is due to coordinate systems, is there any big picture way to describe the differing co-ordinate system? For example of "big picture" language that would be perfect for me, is one co-ordinate system selected so that all points that are equidistant from the center have the same time speed, while the other is drawn so all points have the same defined distance (to a local observer) to the center?
$r$ isn't a physical radius; it's just a coordinate. If you plug $r = m + \sqrt{m^2 - a^2}$ and $t=\text{const}$ into the Boyer-Lindquist metric, you get
$$ds^2 = ρ^2 dθ^2 + \frac{r_s^2}{ρ^2} r^2 \sin^2 θ\,d\phi^2$$
which has a dependence on $θ$. Of course, $θ$ is also just a coordinate, so that doesn't prove that the surface isn't geometrically spherical. But if you calculate the Gaussian curvature (which is half the Ricci scalar), you'll find it's not constant, which does prove it isn't a sphere.
benrg
  • 29,129
