I'm trying to find the amplitude of steady state response of the following differential equation:
$$\ddot{x}+2p\dot x + {\omega_0}^2x=\cos(\omega t)$$
A particular solution is $$x_p=\Re{\dfrac{e^{i\omega t}}{\omega_0^2 - \omega^2 + i2p\omega}} $$
The amplitude at steady state is then $$A=\dfrac{1}{\sqrt{(\omega_0^2 - \omega^2)^2 + (2p\omega)^2}}$$
The denominator has minimum value when $\omega^2 =\omega_0^2 - 2p^2 $: $$A=\dfrac{1}{2p\sqrt{\omega_0^2-p^2}}$$
This expression seems to suggest that the amplitude goes to infinity as $p$ approaches $\omega_0$.
But amplitude has to be finite(from other examples of LRC tank circuit etc).
Pretty sure I'm wrong but not able to see where. Any help?
across
  • 410
You algebra is wrong. If $\omega^2-\omega_0^2=-2p^2$ you get $(-2p^2)^2+(2 p\omega )^2= (2p^2)^2+(2 p\omega )^2$= under the square root and, being the sum of two postive numbers, this can never be zero.
mike stone
  • 58,971
  • 53
  • 158
Without math (or almost ;-)- a system driven by an external forcing function at resonance is accepting energy input that the system cannot easily get rid of. This makes the energy pile up in the system which makes the amplitude of the oscillations grow over time and get big enough to blow it up.
In electrical systems like underdamped RLC circuits, the energy piles up to the point where it makes the system driver emit smoke, or shut itself down through the use of an automatic circuit called a fault detector or foldback which is intended to prevent smoke emission.
This is a big deal because the process of catching the smoke and pumping it back into the system is difficult and expensive.
niels nielsen
  • 99,024
