I'm learning about such things as ionic and covalent bonds, and the reason given for the ionic bonds is electrostatic attraction. However, if that were true, then the two ions would accelerate toward each other and shortly collide with each other. There must be a force opposite the electrostatic force that is repelling the ions, with exactly the same magnitude so as to cancel out the electrostatic force. (Edit: I'm actually referring to the ionic bond between cations and anions in this first paragraph, like sodium and chloride ions. Below is what I found by researching this topic, dealing mainly with covalent/molecular bonding.)
The following quote is from The Mechanical Universe:
For example, the potential energy of a pair of Hydrogen atoms has a position of stable equilibrium. The potential energies of interaction between atoms are due to the electrical forces between them, causing attraction when they're far apart. At smaller distances, they resist being squeezed together. The result is an equilibrium position where attraction and repulsion are in perfect balance. At that position, they bind in a Hydrogen molecule.
I understand that on a larger (planetary) scale, there is a centrifugal potential that is inversely proportional to the distance $r$ that adds up with the gravitational potential to create this graph:
I'm looking for an analogue to this on the molecular scale. I've recently found out about the Lennard-Jones Potential, which gives this equation and curve:$$V_{LJ}=\epsilon \left[ \left(\frac{r_m}{r}\right)^{12} - 2\left(\frac{r_m}{r}\right)^6 \right]$$
In the wikipedia article, it says
...the repulsive term describes Pauli repulsion at short ranges due to overlapping electron orbitals
Later on it is noted that
The repulsive term has no theoretical justification.
So then this is my question: What is the nature of the "Pauli repulsive force"?
If it's possible, I would appreciate an answer with cited sources.
Edit: After some more research, I've found that attraction between two hydrogen atoms (which are both neutral) comes from Induced Dipole-Induced Dipole interaction AKA London Dispersion Forces. Collectively, the attraction and repulsive forces at the molecular scale are dubbed the Van der Waals forces. The wiki on Van der Waals forces mentions A repulsive component resulting from the Pauli exclusion principle that prevents the collapse of molecules. I would like to learn more about how the Pauli exclusion principle manifests itself as a repulsive force between any two atoms/ions.
Greg
  • 1,790
There is an excellent discussion of this at Pauli principle for particles very far apart from each other.
The question isn't a duplicate of yours, so I haven't flagged your question as a duplicate, but Wouter's answer is highly relevant. People have a tendancy to casually throw around the exclusion principle with hand waving arguments such as "when you bring the atoms together the electrons can't occupy the same orbitals". Wouter's answer explains how to understand the exchange force in terms of the electron distributions, and specifically in terms of the overlap.
(Apologies to the mods if this should have been a comment, but it went on a bit long for a comment!)
John Rennie
  • 367,598
The reason is the coulombic repulsion of the two protons. The same is true for $H_2^+$ , the simplest molecule in nature, that has only one electron, and a bound ground state. You can derive the molecular potential analytically if you want and need not think of L-J form with these simple molecules. A place to start is the seminal work by Morse and Stueckelberg, Link
Glorfindel
  • 1,424
  • 17
bla
  • 388
