Suppose a simple circuit with a DC voltage source and a resistor. The voltage of the source will be situated over the resistor. So the electric field (which is the gradient of the potential) will be constant in the resistor (if you assume a linear potential function in the resistor), and will be equal to zero in the conducting connections.
Since electrons are drifted because of an electric field (with Newton's second law and Lorentz' law for the force), what keeps them drifting in the ideal conductors? Or do they just keep their velocity they got in the resistor, and don't decelerate because there's no resistance there? What would mean that the electrons obtain their velocity within the resistor, which sounds a bit paradoxal...
Where's the loop in my argumentation, or am I just right?
BNJMNDDNN
  • 1,083
In idealistic schematics of circuit theory conductors with no voltage drop guide electrons to and from the elements. Electrons don't lose or gain speed here, that is they obey Newton's first law. In resistors there is an acceleration due to electric field and deceleration due to scattering from lattice sites, i.e. drift.
Therefore within this paradigm electrons don't drift in ideal conductors, they act inertially. Thus they will drift through the resistor and go losslessly through contacts into the battery where the electromotive force will bring them to the other side for the next lap. They won't obtain any velocity in the resistor, since they already had it exiting the battery; the electric field in the steady state sets it such that $v=\mu E$.
In reality however even in ballistic conductors, where scattering is largely eliminated and the voltage drop within the ballistic region is vanishingly small, the quantum contact resistance will appear as dominant (and unavoidable - http://www.ecs.umass.edu/ece697mm/Supplement_Lucent_fourt%20resist_Nature_2001.pdf). Therefore there are no such things as ideal conductors, and circuit theory is not particularly suited for analyzing the inner workings of resistivity, conductance, transmission etc.
mgphys
  • 1,729
Yes, in a resistor, the electric field accelerates the electrons. In a resistor, scattering collisions make the average velocity of the electrons in the resistor approximately constant (for a constant DC voltage source).
When the electrons some out of the resistor and enter a superconductor, they begin ballistic conduction. The electrons suddenly being moving in ways described by Newton's laws of motion -- in particular, they initially just keep going at the same velocity they were at when they left the resistor. Just as you suspected.
(A superconductor is more or less by definition a material packed full of movable electrons that electrons can travel through without scattering).
However, (still in accordance with Newton's laws), there can be a transient voltage across a physical superconductor. When that happens, the electrons inside accelerate faster and faster, since there is no scattering to slow them down, until they hit the boundary of (and in some cases exit) the physical superconductor.
I suspect the paradox you are alluding to occurs even without the superconductor. Say we have a battery in New York, and a light bulb in Los Angeles, connected by 2 very long copper wires. If there is a break in either wire near Los Angeles, the light bulb almost instantly goes dark. But after we fix that break, how does the battery miles away almost instantly "know" to start pumping again, pulling electrons out of one wire and pushing them into the other, and somehow those electrons -- creeping along at a few inches per minute -- almost instantly turn on the light bulb? One of my favorite explanations begins "The charges start out inside the light bulb filament." -- William Beaty 1995, and leads us to: What is electricity, really?
David Cary
  • 1,063
