I have this dynamical system $$x'=y, y'=-x^3-y+mx$$ and I want to draw the phace space diagram for $m=-1/8, m=1/4,$ the bifurcation points. 1st of all I cant find what kind of bifruction I have( I go from stable focus to stable node and sadle), does it have a name(?). I compute the equilibrium points and theirs stability and i get these phase portraits for $m=-1/8$:
phase portraits for m=1/4
and for $m=1/4$,
which seem wrong. The grey lines are the trajectories, I computed by numerical integration and plotted the corresponding invariant manifolds (blue and red lines).
Lastly I can drop the Mathematica code I used and let you see if I have any mistakes.
https://we.tl/t-8c4XKGoIKY
Kostas_vaf
Could you be plotting the same phase portrait twice instead, the one for $m=1/4$, instead of plotting two different ones for $m=1/4$ and $m=-1/8$?
I used the following little python script I wrote to help me draw phase portraits of planar vector fields:
import numpy as np
import matplotlib.pyplot as plt
from scipy.integrate import solve_ivp
def solve_IVP(vector_field, x_in, y_in, t_stop, resolution): s_0 = 0 s_1 = t_stop y0 = np.array([x_in, y_in]) t_span = np.linspace(s_0, s_1, num=resolution) sol = solve_ivp(vector_field, [s_0, s_1], y0, method='Radau', t_eval=t_span)
return sol.t, sol.y
def plot_dynamics_and_multi_traj1(vector_field, IVPs, x_left, x_right, x_res, y_down, y_up, y_res, density, normalized): ''' vector_field = the function defining the vector field V to be integrated: input: x and y (arrays of) coordinates output: a tuple of (arrays of) V_x and V_y calculated coordinates IVP = array of arrays, each row contains: [x_initial, y_initial, t_stop = time to stop, number of discrete points in the time interval from [0, t_stop] (as float)] x_res = number of nodes on the x-axis y_res = number of nodes on the y-axis density = density of blue background trajectories to be drown normalized = set to False, unless you want to integrate the unit-normalized vector field, aligned with the original vector field.
''' if normalized: def vf(t, y): v = np.array( vector_field(y[0], y[1]) ) return v / np.sqrt(v.dot(v))
else:
  def vf(t, y):
      return np.array(vector_field(y[0], y[1]))
fig, ax = plt.subplots()
ax.set_aspect('equal')
x_min = x_left
x_max = x_right
y_min = y_down
y_max = y_up
for IVP in IVPs:
   x_in = IVP[0]
   y_in = IVP[1]
   t_stop = IVP[2]
   res_IVP = int(IVP[3])
   sol = solve_IVP(vf, x_in, y_in, t_stop, res_IVP)
   x_min = min(min(sol[1][0,:]), x_min)
   x_max = max(max(sol[1][0,:]), x_max)
   y_min = min(min(sol[1][1,:]), y_min)
   y_max = max(max(sol[1][1,:]), y_max)
   ax.plot(sol[1][0,:], sol[1][1,:], 'r')
x, y = np.meshgrid(np.linspace(x_min, x_max, x_res),
                   np.linspace(y_min, y_max, y_res))
Vx, Vy = vector_field(x, y)
if type(Vx) != object:
    Vx = Vx * np.ones(x.shape, dtype=float)
if type(Vy) != object:
    Vy = Vy * np.ones(x.shape, dtype=float)
ax.streamplot(x, y, Vx, Vy, density=density)
plt.grid()
plt.show()
return None
and applied it to your vector field
$$\vec{\text{VF}}(x, y) \, =\, y \, \frac{\partial}{\partial x} \, +\,\big( -x^3- y + m\, y \, \big)\frac{\partial}{\partial y}$$
# equations defining the vector field:
def VF(x, y):
  return (y,  -x**3 - y - m*x)
I set up a list of starting points selected horizontally over and under the x-horizontal axis (initial value parameters IVPs):
# bifurcation parameter
m = 1/2
how many equally spaced nodes to select along the x-axis
x_res = 100
how many equally spaced nodes to select along the y-axis
y_res = x_res
the right endpoint of the plot on the x-axis
x_size=0.5
the top endpoint of the plot on the y-axis
y_size=0.3
for how much time to integrate the trajectories
stop_time = 12
number of points along each trajectory to be used for integrating the equations
sample_points_on_trajectory = 500
setting up the initial values:
choose an array of initial points for a finite number of solution trajectories:
set up the x-coordinates of the initial points:
IVPs =np.arange(-x_size, x_size, 2*x_size/10) IVPs = np.concatenate((IVPs, - IVPs), axis=0)
set up the initial value parameters:
row1 = x-coordinates of initial points
row2 = y-coordinates of initial points (left empty for now)
row3 =
IVPs = np.array([IVPs, np.empty(len(IVPs), dtype=float), stop_time * np.ones(len(IVPs), dtype=float), sample_points_on_trajectory * np.ones(len(IVPs), dtype=float)])
initializing row2 = y-coordinates of initial points:
below the x-axis
IVPs[1 , 0:int(IVPs.shape[1]/2)] = - y_size
above the x-axis
IVPs[1, int(IVPs.shape[1]/2): IVPs.shape[1]] = y_size
transpose the initial value parameters:
IVPs = IVPs.T
and plotted the following two phase portraits: $$m = \frac{1}{4}$$
m = 1/4
plot the phase portrait:
plot_dynamics_and_multi_traj1(VF, IVPs,-x_size, x_size, x_res, -y_size, y_size, y_res, density=0.7, normalized=False)
and $$m = -\,\frac{1}{8}$$
m=-1/8.
plot_dynamics_and_multi_traj1(VF, IVPs,-x_size, x_size, x_res, -y_size, y_size, y_res, density=0.5, normalized=False)
As you can see, when the bifurcation parameter $m$ goes from positive to negative values, the stable equilibrium point changes from being asymptotically stable focus to three equilibria, one saddle point in the middle and two symmetric stable nodes.
Futurologist
  • 2,621
