They do reduce the heating bill, but.. Let's see some numbers.
The average power consumption of (i) a fridge is 50-100 W, (ii) a television is 50 W, (iii) a laptop is 50-100 W etc. Average power consumption of my household was in the order of 200 W which equals to about 150 kWh per month. Double those numbers and it is still nowhere near enough what an average household needs for heating. Not to mention the appliances are usually not in the same room but rather distributed around the house. While on the topic, I will just mention here that an average person outputs about 50-100 W of heat power, which you can easily verify from the average daily energy consumption of a person which is about 2000-3000 kCal (1 kCal = 4184 J and 1 W = 1 J/s).
The recommended heating power is around 60-70 W/m2 for mild climates and 70-85 W/m2 for cold climates. For a room of 20 m2 (an average-sized living room), you need from 1200 W to 1700 W of heating power. Not to mention there are other rooms in a house which also need heating.
I had a crypto miner briefly which was drawing about 1200 W, most of it converted to heat. In my living room I did not need to turn on the heating. But it does not mean I was saving money in the end, because my heating system was based on gas which is in general (much) cheaper than resistive heaters (electricity) per kWh of heat. How much is the gas cheaper than electricity? It very much depends on the country, but in my experience it ranges from 2 to 5 times. See related discussion on crypto miners and heating: Does bitcoin miner heat as much as a heater
Note that (new) fancy air conditioning systems based on heat pumps are comparable to gas (or even better in some countries!) when it comes to operation cost, i.e. they give more heat power than they consume electricity. How? They take heat from the outside air no matter how cold it is - in reality, they work down to about -10 C.
To conclude - yes, the appliances are reducing the heating bill during a cold season, but not by much! And when you take into account that you have to cool down more during a summer season due to the same appliances producing unwanted heat, in best case the operation costs average out to zero throughout the year.
