For the same generated and transmitted RMS value of power from an electrical power plant station, which transmission line used, assuming having the same wire specification (i.e. wire material conductivity, length, diameter etc) will exhibit the most power losses in the form of heat a DC or an AC line and why?
We assume besides both lines having the same wire specifications also being of the same length and that in the AC power line (50 or 60Hz) there are no intermediate voltage step-up transformers.
What is analytically the contribution of the skin effect on such an AC power (i.e. 50 or 60Hz) line to its power loss? Will this skin effect on the AC line make its losses more than the normal ohmic power loss of the DC line?
I'm asking because I have read assuming that both lines are identical, the power loss to heat per unit length is higher in an AC power line than in a DC power line and try to understand what is the physical reason. Keep in mind that the major reason why AC line was preferred over DC historically and until today is that the voltage can be step-up with transformers allowing longer transmission of electrical power (i.e. voltage drop in the line is a small fraction of the total transmitted).
However, the question remains, does a DC power transmission line have less power loss per unit of length?
