If we establish a changing magnetic field in a region of space, circular electric field lines are induced. This electric field extends even after we exit the region of the magnetic field. If a closed path lies completely outside the magnetic field region, it experiences zero EMF $$\int \vec E \cdot d \vec s = -\frac{d \phi}{dt}=0.$$ My question is, why does the integral cancel out to zero if loop is outside the magnetic field but is non-zero inside where also the electric field lines are circular (geometry is same)? The only difference is the radial dependence of induced electric field ($\vec E \propto r$ inside and $\vec E \propto 1/r$ outside). Is there an intuitive explanation for this?
image of induced electric field from changing magnetic field. Reference image for above text
Note: kindly use integral equations instead of differential ones in the explanation. Both would be valid, but as a high school student I don't understand them well.
Dodo
  • 627
The difference in the radial dependence is the reason.
Circulation over any loop $\gamma$
$$ \oint_{\gamma} \mathbf E \cdot d\mathbf x $$ can be expressed as integral over any surface $\Sigma$ whose boundary is the loop $\gamma$: $$ \oint_{\Sigma} \nabla \times \mathbf E \cdot d\boldsymbol \Sigma, $$ where $\nabla \times \mathbf E$ is called curl, and is a vector whose direction is perpendicular to plane in which circulation per unit area is the greatest, and length is circulation per unit area.
Let there be a cartesian coordinate system oriented in such a way that z axis is in direction of magnetic field, and electric field lines lie in the xy plane.
This curl can be calculated in cartesian coordinates using the standard method: $$ (\nabla\times\mathbf E)_x = \partial_z E_y - \partial_y E_z, $$
$$ (\nabla\times\mathbf E)_y = \partial_z E_x - \partial_x E_z, $$
$$ (\nabla\times\mathbf E)_z = \partial_x E_y - \partial_y E_x. $$
Let the loop lie in xy plane. Then curl in that plane has only z component
Field components inside the solenoid (or cylindrical region with uniform magnetic field) can be expressed as
$$ \mathbf E = Cr\mathbf e_{\varphi} = C(-y,x,0) $$ with non-zero $C$ and thus z-component of curl of this field is
$$ \partial_x E_y - \partial_y E_x = C -(-C) = 2C. $$
Thus any circulation integral in this region comes out nonzero.
For field outside the magnetic field, we have $\vec{E}=\frac{C}{r}\mathbf e_{\varphi}$, or
$$ \mathbf E = \frac{C}{r^2}(-y,x,0). $$
When we calculate curl of this using the above rules, we get zero. Thus curl, that is circulation per unit area, is zero everywhere where field is given by the above formula. Thus circulation over any loop there comes out zero.
-1
I believe you are describing the Aharonov–Bohm effect total wrong in reverse.
$E_{ind}$ in your illustration is actually the $A$ magnetic vector potential:
Aharonov-Bohm effect
image source (modified): https://www.youtube.com/watch?v=1P68eba7zEs
With $B=0$ outside you still get a non-zero induced electric field $E_{in}$ (i.e. Induced Electric Vectors in your illustration are actually the magnetic vector potentials $A$).
It is an quantum interference effect. No one knows the physical explanation of this? Electric charges can somehow "smell" a totally confined and isolated changing magnetic field at a distance.
Dodo
  • 627
Markoul11
  • 4,572
