10
Why are streams of energy-matter emitted along the axis of rotation of compact objects?
(or) what is the reason that they are emitted along the axis of rotation of a compact object?
polar jet herbig haro object
dan
  • 101
This is a big, unsolved issue in astrophysics. What we know is that it's always associated with accretion: that can be during the formation of a star (a 'protostellar jet'), gas accreting around a supermassive black hole (e.g. a 'radio-loud quasar'), or the formation of a stellar-mass black-hole (e.g. during a 'Gamma Ray Burst'). It seems that cases like protostellar jets are somewhat different from jets around compact objects (neutron stars and black-holes). What we think is that it requires rotation and magnetic fields (these requirements can be relaxed a little in the case of protostellar outflows, but I'm not going to discuss that.
There are two things you need to produce a jet:
  • 1: A power source (something to give the outflow energy)
  • 2: Collimation (something to keep the outflow in a beam/cone shape)
and there are different ideas about how to do each.
Power
enter image description here (http://www.kosmologika.net/Blackholes/Sa_driver_svarta_hal_kvasarer.html)
Perhaps the most common mechanism proposed for powering a jet is called the Blandford-Znajek Process---in which the twisting of magnetic fields from a rapidly rotating black-hole (or similarly for a neutron star) transfer rotational energy to outflow energy. The twisted magnetic field lines tend to push outwards.
In some situations it's possible that the immense magnetic field from a magnetar, forced to radiate due to a high spin (called 'dipole emission' also seen in pulsars), could also power a jet. Some people even think that there is enough heat and electromagnetic radiation near the poles of the central object that they would provide enough energy for a strong outflow (this is likely the case in many protostellar jets).
Collimation
One of the nice features of the Blandford-Znajek (BZ) mechanism is that it automatically deposits energy in a conical shape (just like we need for a jet). Even without the BZ mechanism, magnetic fields are believed to help collimate (because plasma tends to flow along the field lines which themselves are collimated by twisting from a spinning source).
enter image description here (http://ned.ipac.caltech.edu/level5/March08/Ho/Ho8.html)
There is also lots of talk about collimation from hot coronae and thick-disks. The idea here (see the picture above) is that if the accretion disk around the central object is hot enough, it gets puffed up into a thick disk---which tends to have a lot of material blowing off of it in all directions. Because of the geometry of the system, outflows along the axes tend to be squeezed together (and maybe even given a helpful push). One feature of this model is that the jet needs to be aligned with the rotational axis of the accretion disk, instead of the rotation of the central object.
