This is probably a very basic question, but I was not really sure how to look it up. I am thinking of watercooling some CPUs with one loop. I can either create one loop with T-Connectors (green design) or use distribution plates (red). Also a mix (distro in, T out, etc) would be possible. How do I get (more or less) the same flow on every CPU or would that be the same result with either approach?
EDIT: The right approach seems to be the Tichelmann System - I hope I got it right.
Two routing are possible - from what I understand the RED arrow would be better/closer to the correct layout then the green one.
