-2
Is magnetic force pseudo
Magnetic force exist only if charge is moving, so it must be pseudo. Imagine, a positively charged man who has the same speed as electron (charge). So, he doesn't feel any magnetic force as charge is at rest with respect to him. Therefore, he only experience electric force.
However a man who is at rest or has different speed than electron feels a magnetic force
Therefore magnetic force must be pseudo. Pls answer me
Vaibhav Tiwari
  • 405
No, the magnetic force is not a pseudo force.
  1. all pseudo forces are proportional to the mass of the thing on which the force is acting, but the magnetic force is proportional to the charge.
  2. all pseudo forces disappear in an inertial frame, but the magnetic force exists in an inertial frame
Dale
  • 117,350
Here is why the magnetic field is pseudo while the electric field is not: people assumed that under a physically-non-exist mirror flip, the charge remains its sign. That directly indicates that the electric field is vector while the magnetic field is pseudo. If people assume the magnetic monopole (which people haven't observed!) remains the sign after the mirror flip, then the magnetic field will be vector. These are just based on common-sense definitions. Being pseudo or not is just in different representations of the mirror symmetry.
Back to your question. The force is not pseudo, because both the magnetic field and the magnet or the monopole if existed will transform under the same representation and therefore the improper factor $(-1)^{\mathrm{det(rep)}}$ get multiplied twice which will give $1$.
RoderickLee
  • 1,117
I read sometime ago in a book (Purcell - Electricity and Magnetism ch. 5.6):
If you have an extense wire with net charge desnsity equal to zero in some referencial, i.e. its linear density $\rho_r = 0$, in such way: You have the positive charges non-moving but with some space between them and moving negative charges.
Suppose you have another charge in some point around the wire and it's at rest in this referential.
If you go to another referential, using relativity stuff, you can show that now you'll have a net charge density in the wire and it'll exerce a force in that charge that's quite equal the Magnetic force that shoub be acting (it's even proportional to the current).
Soo, you can understand magnetic force, in first approximation, as an "relativistic face" of the electric force.
I extremely recommend you to read the chapter I said above, I'm not good trying to explain such things.
