  • We've a vector $\mathbf{A}$ lying in space and changing according to some rule.
  • We introduce an inertial frame and find $\left(\frac{d}{d t} \mathbf{A} \right)_{i n}$ in it.
  • We also introduce a co located frame rotating with $\mathbf{\omega}$. In this rotating frame I find $\left(\frac{d}{d t} \mathbf{A} \right)_{rot}$
  • There exists a relationship between the two time rates as $\left ( \frac{d\mathbf A}{dt} \right )_\text{inertial} = \left ( \frac{d\mathbf A}{dt} \right )_\text{rot} + \boldsymbol \omega \times \mathbf A$
  • In all of this derivation it was assumed that the vector $\mathbf{A}$ was independent of the coordinate system. We merely observed the vector in two frames. The vector is independent of the coordinate system.
  • Can we use the above equation on angular momentum vector $\mathbf{L}$ i.e $\left ( \frac{d\mathbf L}{dt} \right )_\text{inertial} = \left ( \frac{d\mathbf L}{dt} \right )_\text{rot} + \boldsymbol \omega \times \mathbf L$?
I think no we can't.
In the derivation of the $\left ( \frac{d\mathbf A}{dt} \right )_\text{inertial} = \left ( \frac{d\mathbf A}{dt} \right )_\text{rot} + \boldsymbol \omega \times \mathbf A$ we assumed that the vector $\mathbf{A}$ was independent of the coordinate system, its lengths and direction in space is independent of the coordinate system.
However for $\mathbf{L}$ that isn't the case. $\mathbf{L}$ has a different length in a stationary frame than in a rotating one. So the derivation doesn't apply.
Kashmiri
  • 1,390
