Electrons repel by Coulomb interaction. When they get too close, Pauli exclusion principle ("Exchange interaction") becomes important. If their spins are parallel, they are further "pseudo-repelled". If they are anti-parallel they are "pseudo-attracted".
In an Hydrogen-2 molecule, both electrons are the "bonding glue" that lowers the energy of the molecule. They may repel each other, but overall staying close together between both protons lowers the total energy. So having anti-parallel spin lowers their repulsion, helping them stay together as "glue".
So like with Hydrogen-2, I would expect the exchange interaction in all materials to favor anti-parallel spins in close electrons to lower their repulsion. But this is not what happens in reality.
In ferromagnetic materials, the opposite happens. This I don't understand. When their 'atomic' & 'free' electrons get close, instead of becoming anti-parallel (which would help reduce the unstability of their repulsive proximity), they become parallel. In my very limited understanding, this should make the material have higher energy and be more unstable.
I thought that maybe, because of some complicated molecular orbital structure of the ferro-material, those particular electrons are not "bonding glue", so when they do get close together their repulsion actually destabilizes the material. But then, making them parallel will just make that repulsion even worse! So I still don't understand how the exchange interaction could ever make them parallel. It always seems like the more unstable state.
Could anyone show me how is my crude reasoning wrong?
Juan Perez
  • 3,082
In ferromagnetic materials the magnetism does not come from valence electrons but from unpaired d-electrons. These are spin aligned in agreement with Hund's rules. The valence electrons in such a material are generally paramagnetic.
my2cts
  • 27,443
-1
Pauli exclusion principle is a principle because its cause is not quite clear. But, if you consider - only for the time of the consideration of your enumerated facts and the questions - the electrons not only as charges but also as small magnets, everything fits together logically. Replace the orientation of the spin with the orientation of a bar magnet and you get an intuition what happens in the described phenomena.
This phenomenon occurs in atoms. The electrons coupled to the atomic nucleus have a reduced electric potential and thus come close to each other. At this point, the electrons are primarily under the influence of their magnetic dipoles, which align themselves antiparallel in pairs at their lowest energy level.
Ferromagnets always have an odd number of electrons, that is, one unpaired electron. At sufficiently high temperature, the thermal motion to which the atoms are subjected prevents self-alignment of the atoms in the material.
Below the Curie temperature, the unpaired electrons have an influence on each other via their magnetic dipoles and a common alignment occurs.
How can the exchange interaction make electron spins parallel?
The exchange interaction can be made intuitive with the magnetic dipoles. That an anti-parallel spin has a lower energy level than a parallel spin is a principle as well as the Pauli exclusion principle. The alignment of magnetic dipoles on the other hand is an observable phenomenon and seems to be successfully transferable to the interaction of bonded electrons.
HolgerFiedler
  • 10,980
