If there is a satellite and it is in an elliptical orbit. At the aphelion, it accelerates from its elliptical orbit to a circular orbit.
The thing that confuses me is that when the satellite is at aphelion, there's no radius velocity. Thus, it's proper to use the formula for a circular motion ($G\frac{Mm}{R^2}=\frac{mv^2}{R}$) to calculate the velocity of the satellite at aphelion. Then if it is accelerated to a circular orbit at aphelion. In order to calculate the velocity when the satellite is in a circular orbit, we still use the same formula with the same radius, same mass, and so on to calculate the velocity of the satellite.
Then what about the change in angular momentum. When the satellite is in an elliptical orbit, in order to calculate the angular momentum, we can calculate the velocity when the satellite is at aphelion, the radius of aphelion, and the mass of the satellite. However, when the satellite is after acceleration and in a circular orbit, the velocity, radius, and mass do not change. As a result, the angular momentum is not changed, but this is impossible since we need the impulse to let the satellite leave its original elliptical orbit. Where I go wrong? Thanks
