I've been told that the radiation pressure of light can be understood(?) by considering a charged particle as a damped driven harmonic oscillator where the forcing term is the electromagnetic field, not neglecting the magnetic field term. In fact, I am told that the magnetic field term is responsible for the radiation pressure. I've already learned about the classical theory of light dispersion by treating the oscillator, neglecting that term. I'm trying to figure out the average force of light pressure on this electron-oscillator and having a difficult time. Since the equation for the force is $$\vec F=e(\vec E+\frac{1}{c}(\vec v\times \vec H)),$$ I'm imagining that there is no light pressure on the oscillating charged particle when it's at its extrema, and the max light pressure is when it's at the midpoint... but I can use information that I have externally to say that $F=\frac{\Delta E}{c\Delta t}$, where I already calculated the average rate of energy for the driven-damped oscillator differential equation neglecting the magnetic field, which oddly enough is given again for this problem. I simply don't understand how to connect what I know from the seemingly much simpler ways to derive and understand radiation pressure, to the magnetic field term.
Does anyone have any awareness or intuitive explanation for how radiation pressure comes out of the magnetic field force? I don't even understand how it is that it depends on a nonzero velocity (seems false).
