I've seen the simple experiment of dropping a neodymium sphere down through a copper or aluminum tube where it falls at less than g. The "Lenz Effect"
My question is:
Has there ever been an experiment when the NeoD sphere is tied to a string attached to a weight scale? Does the sphere weigh less at the midpoint inside of the tube than it does moving outside of it?
Sandejo
  • 5,496
ClancyJohn
  • 111
Someone may have done such an experiment, but it would be messy. It would be a lot easier to measure how long it takes the magnet to fall through the tube to get the same result.
Assuming the magnet falls with a uniform acceleration, since $$y=\frac{1}{2}at^2 \\ \rightarrow a=\frac{2y}{t^2}$$ Since you know the length of the tube $y$, and if you measure the time the magnet takes to fall through the tube $t$, then you can calculate the net acceleration of the magnet.
From this you can calculate the (net) force applied on the magnet, which is simply $$F_N=ma=\frac{2my}{t^2}$$ where $m$ is its mass. This force will obviously be smaller than the magnet's weight force.
joseph h
  • 31,821
