I know from Weinberg and Schwartz's book on Quantum Theory of Fields that $SL(2, \mathbb{C})$ double-cover $SO^{+}(1,3)$.
However, moving to the Lie algebra, based on the following wiki:
https://en.wikipedia.org/wiki/Representation_theory_of_the_Lorentz_group
we have $so(1,3)_{\Bbb C} \cong sl(2,\Bbb C)_{\Bbb C} \cong sl(2,\Bbb C) \oplus sl(2,\Bbb C)$
where $_{\Bbb C}$ indicates the complexification.
Now, if we move from the Lie algebra to the group, by exponentiating, the last term above gives $SL(2,\Bbb C) \times SL(2,\Bbb C)$
So my questions are:
  1. What is the Lie group related to $so(1,3)_{\Bbb C}$?
  2. In $so(1,3)_{\Bbb C} \cong sl(2,\Bbb C)_{\Bbb C} \cong sl(2,\Bbb C) \oplus sl(2,\Bbb C)$, the algebras are viewed as real or complex algebraS?
  3. On most of the books in QFT from the following brackets for $so(1,3)$:
$[J^+_i,J^+_j] = i\epsilon_{ijk}J^+_k,\,[J^-_i,J^-_j] = i\epsilon_{ijk}J^-_k, \, [J^+_i,J^-_j]=0$
where $J^+=1/2(J_i+iK_i), \, J^-=1/2(J_i-iK_i)$
they deduce $so(1,3) \cong su(2) \oplus su(2)$
Shouldn't they deduce $so(1,3)_{\Bbb C} \cong su(2)_{\Bbb C} \oplus su(2)_{\Bbb C}$?
DanielC
  • 4,497
  • 25
  • 39
Andrea
  • 826
The group $\mathrm{SL}(2,\mathbb{C})$ is isomorphic to the double cover of ${\rm SO}(1,3)$. In that case the relation between the two can be expressed as $${\rm SO}(1,3)\simeq {\rm SL}(2,\mathbb{C})/\mathbb{Z}_2\tag{1}.$$
The other kind of relation you mention is just a bit more subtle and is often stated without much care, leading to confusion. Starting form ${\rm SO}(1,3)$ build its Lie algebra ${\frak so}(1,3)$. This is a real Lie algebra and as with any vector space over $\mathbb{R}$ it can be complexified. Constructing the complexification ${\frak so}_\mathbb{C}(1,3)$ we can show that $${\frak so}_\mathbb{C}(1,3)\simeq \mathfrak{su}_\mathbb{C}(2)\oplus \mathfrak{su}_\mathbb{C}(2)\tag{2}.$$
In truth there is nothing complicated here. The generators $J_{\mu\nu}$ of ${\mathfrak{so}}(1,3)$ can be split into generators of rotations $\mathbf{J} = (J^{23},J^{31},J^{12})$ and of boosts $\mathbf{K} = (J^{10},J^{20},J^{30})$. Since $\mathfrak{so}(1,3)$ is a real Lie algebra you can only form combinations of such generators with real coefficients. Complexification is just a fancy terminology to say that we are now allowing to form linear combinations with complex coefficients. These linear combinations of the generators with complex coefficients do not live on $\mathfrak{so}(1,3)$ but rather on $\mathfrak{so}_\mathbb{C}(1,3)$.
The reason complexification is essential is that it allows us to form $$\mathscr{A}_i = \frac{1}{2}(J_i+iK_i),\quad \mathscr{B}_i=\frac{1}{2}(J_i-iK_i)\tag{3},$$
the advantage of this being that the Lorentz algebra of the generators $J_i, K_i$ is equivalent to the $\mathscr{A}_i$ and $\mathscr{B}_i$ separately satisfying the $\mathfrak{su}_\mathbb{C}(2)$ algebra. This is what (2) is all about.
So complexified $\mathfrak{so}(1,3)$ is isomorphic to a direct sum of two complexified $\mathfrak{su}(2)$. That is the proper relation. It is useful in the end because it allows you to build representations of $\mathfrak{so}_\mathbb{C}(1,3)$ out of those of $\mathfrak{su}_\mathbb{C}(2)$ which are known from the theory of angular momentum.
Finally I should mention that sometimes people write ${\rm SO}(1,3)\simeq {\rm SU}(2)\times{\rm SU}(2)$. This is incorrect and what they actually have in mind is (2) above.
Gold
  • 38,087
  • 19
  • 112
  • 289
