Consider the objects $$A_\mu, ~~F_{\mu\nu}:=\partial_\mu A_\nu-\partial_\nu A_\mu,$$ and the objects $$A:=A_\mu dx^\mu,~~F:=\frac{1}{2!}F_{\mu\nu} dx^\mu\wedge dx^\nu.$$ While reading it from Zee's book on Quantum Field Theory in a Nutshell, I acquired the idea that the entities $A$ and $F$ defined above are examples of a 1-form and a 2-form respectively.
However, now going through Sean Carroll's book Spacetime and Geometry Section 2.9, I find that a $p$-form is defined as $(0,p)$ tensor that is completely antisymmetric. But if this definition is correct, then $F_{\mu\nu}=\partial_\mu A_\nu-\partial_\nu A_\mu$ is a 2-form not $F$. It also says that $\epsilon_{\mu\nu\sigma\rho}$ is a 4-form.
Please explain between $F_{\mu\nu}$ and $F$, what stands for a two-form.
In the physics literature it is quite common to casually refer to the components of a tensor as the tensor. The same practice is used for differential forms.
It's important to distinguish between a tensor and the components of a tensor. A (r,s) tensor is a multilinear map that takes r co vectors and s vectors, and maps them into the reals. In that case $dx^\mu$ takes a vector V and maps into the the reals, $dx^\mu(V) = V(x^\mu) =V^\mu$. Now here comes the tricky bit, $V^\mu$ is not a vector, but a component of a vector, i.e. a real number. Similarly, in your example, $F_{\mu\nu}$ and $A_\mu$ are real numbers, while $F$ and $A$ are a one and two form respectively.
Filipe Miguel
  • 580
  • 16
$F$ is a (0,2) tensor, i.e. a bilinear map $F : V\times V \to K$ , where V is a vector field defined over field K. If $\{\partial_{\mu}\}$ be the basis vector for V and $\{dx^{\mu}\}$ be the corresponding dual basis vector satisfying $dx^a(\partial_b)=\delta^a_b$, then $F_{\mu\nu}=F(\partial_{\mu}, \partial_{\nu})$. If we are considering U(1) gauge theory, then $F\equiv dA$. So, $F_{\mu\nu}=dA(\partial_{\mu},\partial_{\nu})=\partial_{\mu}A_{\nu}-\partial_{\nu}A_{\mu}$ where we have used the definition of the exterior derivative of a 1-form $\omega$ : $d\omega (X,Y):=X(\omega(Y))-Y(\omega(X))-\omega([X,Y])$
KP99
  • 2,027
  • 18
