Suppose an angular oscillatory motion. In the function below, $\alpha$ and $\alpha_o$ are angles measured in radian, $\omega$ is circular frequency ($2\pi/T$) measured in [radian/s] and $t$ is time.
$$ \alpha = \alpha_o\sin(\omega t) $$
Angular velocity is obtained by taking derivative with respect to time:
$$ \frac{d\alpha}{dt} = \alpha_o\omega\cos(\omega t) $$
I get confused with the unit of angular velocity. To me it looks like:
$$ \frac{d\alpha}{dt} = \alpha_o[rad]\omega[rad/s]\cos(\omega t)[1] =[rad^2/s] $$
Why I cannot get $rad/s$ for angular velocity?
Shibli
  • 113
It is radians squared. The problem is you are using two different radians. One is the physical angle $\alpha$, which oscillates with amplitude $\alpha_0$. Fine...you could measure that in degrees, say if it were a latitude or longitude. That might make the point clearer, or at least less abstract.
The other angle is the temporal phase angle of the oscillatory function:
$$\phi(t) = \omega t $$
So, these two angles live in different spaces, and their radians aren't the same thing. Of course, you can also just not use radians, and they are dimensionless (with good reason: space radians and time radians don't mix well, as you discovered).
JEB
  • 42,131
Radian is defined in such a way that it has no unit. So we cannot mathematically differentiate between a numerical constant and a unit. And this leads to many confusions. Using degree as unit of angle will make this more clear.
Let $\alpha,\alpha_o,\omega,t$ be numerical value
$$ \alpha^\circ = \alpha_o^\circ\sin\left(\left(\frac{\omega^\circ}{s}\right)\left(\frac{\pi}{180^\circ}\right)\left(t\space s\right)\right) $$
$$ \left[\frac{d\alpha}{dt}\left(\frac{^\circ}{s}\right)\right] = \left[\alpha_o^\circ\left(\frac{\omega^\circ}{s}\right)\left(\frac{\pi}{180^\circ}\right)s\cos\left(\left(\frac{\omega^\circ}{s}\right)\left(\frac{\pi}{180^\circ}\right)\left(t\space s\right)\right)\right]$$
$$\implies \left(\frac{^\circ}{s}\right)=\left(\frac{^\circ}{s}\right)$$
