I am running at $5 \text{ ms}^{-1}$ and holding a torch pointing in the direction of motion. This torch has a large block of glass attached to the end. Would a stationary observer see the light as moving at the speed of light in glass ($2 \ 10^8 \text{ ms}^{-1}$) or as $5 \text{ ms}^{-1}$ faster? What if I was moving at $1 \ 10^8 \text{ ms}^{-1}$ or $2 \ 10^8 \text{ ms}^{-1}$?
Asked
Active
Viewed 281 times
To determine the speed of light in a moving medium you use relativistic velocity addition. The first velocity is the speed of light in the medium (when the medium is at rest) and the second velocity is the speed of the medium.
Dale
- 117,350
The short answer is "no". There is only one speed that is invariant (the same for all observers). That particular special speed $c$ is often called the "speed of light" because light travels at that speed in vacuum. But it's the speed that's important, not the light -- that is, if light is slowed down by a medium, it's no longer traveling at the special speed $c$ and hence its speed is determined just the same as the speed of anything else (using the usual relativistic formula for adding velocities).
Eric Smith
- 11,450
