The Fourier transform of $y\left(x,t\right)$ from the time to the frequency domain is given by $Y\left(x,\omega\right)=\int_{-\infty}^{\infty}y\left(x,t\right)e^{i\omega t}dt$ and satisfies the differential equation:
EI\frac{\partial^{4}Y\left(x,\omega\right)}{\partial x^{4}}+\mu\left(i\omega\right)^{2}Y\left(x,\omega\right)=\int_{-\infty}^{\infty}P\delta\left(x-u\left(t\right)\right)e^{i\omega t}dt
Now, use this property of the delta function:
\delta\left(g\left(s\right)\right)=\sum_{i}\frac{\delta\left(s-s_{i}\right)}{\left|g'\left(s_{i}\right)\right|}
where $s_{i}$ are the roots of the function, so that $g\left(s_{i}\right)=0$.
\int_{-\infty}^{\infty}P\delta\left(g\left(t\right)\right)e^{i\omega t}dt=\int_{-\infty}^{\infty}P\sum_{i}\frac{\delta\left(t-t_{i}\right)}{\left|g'\left(t_{i}\right)\right|}e^{i\omega t}dt=P\sum_{i}\frac{e^{i\omega t_{i}}}{\left|g'\left(t_{i}\right)\right|}
Then we have:
\frac{\partial^{4}Y\left(x,\omega\right)}{\partial x^{4}}-\frac{\mu\omega^{2}}{EI}Y\left(x,\omega\right)=\frac{P}{EI}\sum_{i}\frac{e^{i\omega t_{i}}}{\left|g'\left(t_{i}\right)\right|}
The Green's function solution to this equation is:
Y\left(x,\omega\right)=\int_{-\infty}^{\infty}\frac{P}{EI}\sum_{i}\frac{e^{i\omega t_{i}}}{\left|g'\left(t_{i}\right)\right|}G\left(x,x'\right)dx'
The Green's function satisfies the equation:
\frac{\partial^{4}G\left(x,x'\right)}{\partial x^{4}}-\psi^{4}G\left(x,x'\right)=\delta\left(x-x'\right)
Now we have to invert the Fourier transform.
y\left(x,t\right) = \frac{1}{2\pi}\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}\frac{P}{EI}\sum_{i}\frac{e^{i\omega t_{i}}}{\left|g'\left(t_{i}\right)\right|}G\left(x,x'\right)e^{-i\omega t}dx'd\omega
=$$ $$=\frac{P}{EI}\sum_{i}\left\{ \frac{1}{2\pi}\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}\frac{1}{\left|g'\left(t_{i}\right)\right|}G\left(x,x'\right)e^{i\omega\left(t_{i}-t\right)}dx'd\omega\right\}
=$$ $$=\frac{P}{EI}\sum_{i}\frac{1}{\left|g'\left(t_{i}\right)\right|}\int_{-\infty}^{\infty}G\left(x,x'\right)\delta\left(t-t_{i}\right)dx'
Where the definition: $\delta\left(t-t'\right)=\frac{1}{2\pi}\int_{-\infty}^{\infty}e^{i\omega\left(t-t'\right)}d\omega$, has been used. So, this is for a general $g\left(t\right)$. Now, if $g\left(t\right)=x-vt$, then:
y\left(x,t\right) = \frac{P}{EI}\frac{1}{v}\int_{-\infty}^{\infty}G\left(x,x'\right)\delta\left(t-\frac{x'}{v}\right)dx'
= \frac{P}{EI}G\left(x,vt\right)
Not sure why the paper does not have the $EI$ factor.
