In Understanding Molecular Simulation, the following Maxwell Boltzmann distribution for momentum is given:
$$\mathcal{P}(p) = \left(\frac{\beta}{2\pi m}\right)^{3/2}\text{exp}\left[\frac{-\beta p^2}{2m}\right]$$
From this the relative variance of the kinetic energy can be calculated as:
$$\frac{\sigma_{p^2}^2}{\left< \ p^2\right>^2} \equiv \frac{\left< \ p^4\right> - \left< \ p^2\right>^2}{\left< \ p^2\right>^2} = \frac{2}{3} $$
This is used to motivate the fact that the instantaneous temperature of a system in the canonical ensemble will fluctuate also, and its variance can be given as:
$$\begin{split}\frac{\sigma_{T_k}^2}{\left< \ T_k \right>^2_{NVT}} & \equiv \frac{\left< \ T_k^2\right>_{NVT} - \left< \ T_k\right>_{NVT}^2}{\left< \ T_k\right>_{NVT}^2} \\ & = \frac{N\left< \ p^4\right> + N(N-1)\left< \ p^2\right>\left< \ p^2\right>- N^2\left< \ p^2\right>^2}{N^2\left< \ p^2\right>^2} \\ & = \frac{1}{N} \frac{\left< \ p^4\right> - \left< \ p^2\right>^2}{\left< \ p^2\right>^2} = \frac{2}{3N}\end{split}$$
This seems to indicate that:
$$\left< \ T_k^2\right>_{NVT} = N\left< \ p^4\right> + N(N-1)\left< \ p^2\right>\left< \ p^2\right>$$
The instantaneous temperature is:
$$k_B T = T_k = \sum^N_i{\frac{p_i^2}{2mN_f}}$$
Where $N_f$ represents the degrees of freedom and is given as $N_f = 3N-3$. Given this expression, $T_k^2$ is the following:
$$\begin{split}T_k^2 & = \left(\sum_i^N{\frac{p_i^2}{2mN_f}}\right)^2 \\ & = \sum_i^N\sum_j^N{\frac{p_i^2p_j^2}{4m^2N_f^2}} \\ & = \frac{1}{4m^2N_f^2}\left[(p_1^4+p_2^4+... +p_N^4) + (p_1^2p_2^2 + p_1^2p_3^2 + ... + p_N^2p_{N-1}^2)\right]\end{split}$$
When taking the average does this actually simplify down to what is given above? If it does why is it okay to simply say each particles momentum can be represented by the average? If this is incorrect, what method should be used to reach the desired equation for $\left< \ T_k^2 \right>$?
Connor
  • 403
Dimensional analysis tells us $T_k$ (which I assume is short for $k_BT$, with dimensions of energy) should have the dimensions of $p^4/m^2$ rather than $p^4$, so your first method clearly didn't work. (Your fallacy was thinking if $a/b=c/d$ then $a=c$, as opposed to $a=c/(2m)^2$.) What it actually shows (assuming you got the rest of it right) is $\langle T_k^2\rangle=\frac{3N+2}{3N}\langle T_k\rangle^2=\frac{3N+2}{6Nm}\langle p^2\rangle$.
J.G.
  • 25,615
The exponential distribution of kinetic energy has a parameter, called temperature. Its the limit of many subsystems in contact with an infinite bath of given temperature. Anything interesting is coded in that single parameter T, eg all moments and central moments.
A subensemble of such a canonical ensemble, that has lower expectation of energy and is considered isolated, is a microcanocial ensemble with much more complicated densities on surfaces of constant kinetic energy.
If its not isolated the distribution of T makes no sense at all.
