An electron spins around its axis and magnetic field is produced. It can spin either in clockwise $\left(\frac{1}{2}\right)$ or in counterclockwise $\left(\frac{-1}{2}\right)$ direction.
The spin angular momentum is given by $S=\sqrt{s\left( s+1\right) }\cdot \dfrac{h}{2\pi }$.
If $s$ is $\frac{1}{2}$, then the spin angular momentum is $\sqrt{\dfrac{1}{2}\left( \dfrac{1}{2}+1\right) }\cdot \dfrac{h}{2\pi }=\dfrac{\sqrt{3}}{2}\cdot \dfrac{h}{2\pi }$
and If $s$ is $\frac{-1}{2}$, then the spin angular momentum is $\sqrt{\dfrac{-1}{2}\left( -\dfrac{1}{2}+1\right) }\cdot \dfrac{h}{2\pi }=\dfrac{i}{2}\cdot \dfrac{h}{2\pi }$.
Why is the spin angular momentum of $s=\frac{-1}{2}$ imaginary value, is this possible? What is the meaning of this; what does it mean physically when particles have spin half and negative half integer and their spin angular momentum real or imaginary?
You are confusing the square of the spin vector ($\vec{S}^2$) with its 3 vector components ($S_x, S_y, S_z$).
The square of the spin $\vec{S}^2$ always has the value $s(s+1)\hbar^2$, which is positive. And the electron has $s=\frac 12$ (no negative sign).
The components $S_x$, $S_y$ and $S_z$ each have two possible values (a positive and a negative). These are $+\frac 12 \hbar$ and $-\frac 12 \hbar$.
