Assume an electromangetic wave with the wavelength of 1 mm and a straight wavefront of 1 cm wide. So, in vacuum, does the wavefront spread out to the sides and get wider?
P.S. It would be nice if you could explain with what methods we could produce such a precise wave shape, especially on the edges/endpoints of the wavefront as the diffraction tends to prevent it.
Xfce4
  • 774
Due to quantum (and possibly other) effects, primarily the uncertainty principle, there will always be some spread, as explained here. It is not possible, even in principle, to produce a light beam with zero divergence, unless it is infinitely large (in which case is a plane wave). In general, the greater the initial diameter of the beam, the smaller the divergence.
The picture in the article does not accurately depict such a plane wave because the plane wavefronts are actually infinitely large, unlike what the picture seems to suggest.
