According to this Wikipedia article, Alfvén's theorem states that "in a fluid with infinite electric conductivity, the magnetic field is frozen into the fluid and has to move along with it". However, in this Wikipedia article it gives a number of ways particles can drift across the magnetic field due to a 'Nonuniform B'. Do these particles violate Alfvén's theorem? Does Alfvén's theorem only work for fluids and not for test particles?
Peanutlex
  • 555
Yes. In MHD there are no particles, only a fluid. One could, in principle, try to describe the system as being comprised of multiple magnetized fluids including a separate one for the cross-field drifting particles, however such models are not within the confines of ideal MHD. You can see some of the assumptions of ideal MHD at https://physics.stackexchange.com/a/452325/59023 and https://physics.stackexchange.com/a/551944/59023.
In a magnetized plasma with infinite conductivity, the result of this assumption is that the only electric field field which can exist is the convective electric field, i.e., that resulting from Lorentz transformation (see links above for derivation and discussion).
Hans Alfvén only considered magnetized fluids, not kinetic plasmas. So yes, his theorem is only appropriate in the limit where you treat the kinetic plasma as a single, idealized, magnetized fluid.
