Suppose a system (eg: rocket) consists of $N$ atoms. It starts moving away from the origin of an inertial frame at speed 0.9c. Will $N$ changes and if it changes where does this change come (if increases) or goes (if decreases)?
Update: Let's suppose there is no fuel in the rocket and it attains this speed through a sequence (can be a large number) of gravitational slingshots, and the mass 0 we are talking about is calculated after receiving the first slingshot
Follow-up Question: Since $N$ will not change and Total Mass = Sum(mass of all atoms in the system), and according to the equation
$$m = \frac{m_0}{\sqrt{1-\frac{v^2}{c^2}}}$$there is △m increase in Total mass. I want to understand how does this △m came into the system, does the particle mass increase or something else
No there will not be any change. Particle number is Lorentz invariant i.e. the number of Atoms that make up a particular object is the same no matter from which frame of reference you measure it.
SPHerical
  • 558
A rocket uses fuel to move so the fuel particles escape the system; if you roughly know $\Delta m$ and the mass of the fuel particles you can estimate the number of particles that have escaped the rocket. Particle number is Lorentz-invariant so the particles composing the rocket will remain the same in any inertial reference frame.
If the rocket isn't propelled by fuel nor by any $\Delta m$ the number of particles composing the rocket stays the same.
The relativistic mass $m=\gamma m_0$ originating from relativistic speed is not the "real mass" of the system, thus is not associated to particle number. Instead the particle number is associated with the rest mass $m_0$ which is conserved and frame-invariant.
Lorenzo B.
  • 562
  • 16
