In flat Minkowski space with the metric signature (-,+,+,+) the spacetime interval $ds^2$ is defined as
$ds^2 = -c^2 dt^2 + x^2 + y^2 + z^2$
This interval (or better the square of the distance) can become negative (for timelike intervals) so the spacetime distance $ds$ can be complex.
In quantum mechanics a complex quantity is something which cannot be measured. Only real quantities can be measured. Does that mean that the spacetime distance becomes unmeasurable if it becomes complex? Or how is the interpretation in relativity for complex spacetime distances?
What confuses me is that one can also choose a different metric $(+,-,-,-)$. In that case the spacetime interval is
$ds^2 = c^2 dt^2 - x^2 - y^2 - z^2$
Then it is not timelike distances that become complex, but instead spacelike distances will be complex. So it seems to depend ob the convention of the metric signature when the space-time distance will be complex. So do complex spacetime distances (or negative spacetime intervals) have any physical meaning at all?
asmaier
  • 10,250
The scalar $ds^2:=dx^\mu dx_\mu$ is real, but its sign changes when you switch metric convention. Whether $\sqrt{ds^2}$ is real or imaginary is therefore not purely a physical question.
On the other hand, if $ds^2\ne0$ then $dx^\mu$ satisfies either $dt=0$ or $dx^i=0$ in a suitable reference frame, and which is applicable is very much physically relevant. If we can impose $dx^i=0$, the path is causally traversable; if we can impose $dt=0$, the path's endpoints can be regarded as simultaneous events, making them outside each other's light cone. (But you probably know all that.)
If you're interested in the real-complex distinction, it can help to work in proper time $d\tau^2=dt^2-d\vec{x}^2/c^2$, which settles the convention question. Traversable paths have $d\tau\in\Bbb R$; between events we can take to be simultaneous, $d\tau\in i\Bbb R$. But in the latter case, we don't normally consider it convenient to work with proper time.
J.G.
  • 25,615
