26
I teach grade 12 physics and am about to introduce collisions. I am explaining that in elastic collisions, kinetic energy is conserved and in inelastic collisions, kinetic energy is not conserved. The kinetic energy in inelastic collisions can be lost to heat, sound and electromagnetic radiation.
As I think about it though, do heat, sound and light not also have kinetic energy? Heat is movement of particles which is kinetic energy. Sound is movement of air particles which is also kinetic energy. Lastly, if I am not mistaken, light (EMR) has a relativistic kinetic energy.
If you were to track every molecule and photon's kinetic energy after a collision, would kinetic energy be conserved in all collisions?
The only thing that makes me think it wouldn't would be somehow if the energy was converted into some form of potential energy. Like a collision where one object causes another object to increase in height therefore increasing the gravitational potential energy of the object.
Edit: Note, I am not teaching my students anything deeper than the basic macroscopic conception of collisions. While I was prepping, it just got me thinking about this.
Morphyl
  • 444
13 Answers13
14
The definition of an elastic collision between two bodies is one for which the kinetic of energy of the two bodies remains the same after the collision (see https://en.wikipedia.org/wiki/Elastic_collision). A collision can only be perfectly elastic if there is no heat, sound, or light (or anything else) generated as a byproduct of the collision -- any energy devoted into these forms must be subtracted from the total incoming kinetic energy, i.e. the total kinetic energy of the two bodies is not conserved. While light and sound do have kinetic energy, they carry away some fraction of the initial system KE, so the collision is not elastic by definition.
As I see it, the answer to the question "Are all collisions really elastic?", given the definition of elastic, is really no. Not only that, but there is really no example of a perfectly elastic collision on the everyday scale of matter. Even cases where the objects do not touch, for example a fly-by scattering between two stars, generates heat from gravitational tides and would thus be inelastic.
zh1
  • 2,866
Heat
The difference between the collisions of macroscopic and microscopic objects is that the concept of heat is not applicable to the latter. Indeed, thermodynamic concepts work only for large collections of particles, containing of the order of $N_A\approx 10^{23}$ particles.
Collisions at microscale (compound objects)
So a more refined distinction between the elastic and inelastic collisions, is that in the latter some kinetic energy may be converted into the internal energy of the colliding particles. To give a few examples:
  • Atom absorbs a photon, so that an electron in atom moves to a higher energy state, i.e., the energy of the atom is changed, while photon ceases to exist. Note that in this case the internal energy is partially potential and partially kinetic, but it is internal to the atom, which we treat as a whole.
  • Raman scattering is similar to the example above, but the photon is re-emitted with a lower energy. This is perhaps more similar to the idea of collisions in elementary mechanics.
  • Nuclear systems exhibit similar behavior: a nuclei may absorb a neutron or an alpha particle (or deflect it absorbing only part of its energy), while becoming excited, i.e., increasing its internal energy.
Collisions of elementary particles
In all these examples we deal with objects having internal structure, such as atoms or nuclei. In case of elementary particles the collisions are elastic, even though some particles may cease to to exist and others may appear in their place. Again, this is not completely true, since even the elementary particles, such as protons and electrons, do have inner structure in terms of quarks and could probably be excited to higher energy states.
Energy conservation
As pointed in other answers, whether collision is elastic or inelastic, it does not change the fact that the energy is conserved. However, for macroscopic objects the heat and the kinetic/potential energy of the object as a whole are sharply distinct, whereas for microscopic objects this distinction is less obvious - which is probably the main premise of this question.
Roger V.
  • 68,984
There is actually no such thing as an elastic collision at the atomic (or even subatomic) scale, but that is not necessarily for the reason one might think. The reason is that, when collisions are mediated by electromagnetic forces (as most collisions, from the everyday scale down to the molecular scale), the number of quanta involved never remains constant. Any collision or scattering process in which electromagnetism is involved will entail the emission of an enormous number of very, very soft (that is, low frequency) photons. These carry off very little energy, but they are huge in number, limited only by the macroscopic situation in which a microscopic collision might be set.
In low-energy collisions, these electromagnetic excitations go essentially undetected, but they draw a small amount of energy off the initial particles. In nominally two-body collision, the two principal bodies will have slightly less combined energy after the collision than before, because of the profuse emission of very long-wavelength photons. However, at shorter wavelengths, these photons can be seen experimentally. As collisions become more energetic, this soft photon emission spectrum connects up smoothly to the more energetic bremsstrahlung photons that are emitted in fast collisions.
Buzz
  • 17,816
The law of conservation of energy is absolute. In a sense, if nature could be successfully modeled with classical mechanics and classical electrodynamics, at the pedantic level, you would have to include potential energy , as you note, in order to fulfill the law. Classically there is only potential and kinetic energy. In the simplest inelastic collision between two particles, the potential energy in the deformations would not allow to talk about conservation of just kinetic energy.
It gets worse at the quantum level, or at the level of large velocities close to the speed of light , where mass is no longer conserved.To get conservation of energy one has to use models with Lorentz invariance and four vectors.
anna v
  • 236,935
Can It Wiggle?
When computing the dynamics of two colliding bodies, this is a good question to ask. For every molecule, the answer is: yes. That's because the bond lengths of the molecule can vary, making them atomic-scale springs.
As far as I know, nucleons cannot "wiggle" (but I am not a physicist, so take that with a grain of salt). So if you bounce two H atoms together, I believe you should see an "elastic collision". But as soon as you upgrade to H2, you now have molecules that can wiggle, and some of the collision energy can go into making the atoms of a single H2 molecule bounce like a spring. Therefore, such collisions will appear inelastic.
Can It Spin?
If you can orient the colliders, then they may also have angular momentum, so some of the collision energy may be converted to spin, rather than whole-body momentum.
Can It Deform?
If a collider can permanently change its shape, then some of the collision energy may go into reconfiguring its internal bonds. You generally need bigger molecules to observe plastic deformation, but I doubt you need more than 100. Chemists could probably tell us the smallest deformable molecule (I'm guessing less than a dozen atoms of a typical metal could be bent into all sorts of shapes).
Conclusion
Of course, some of these modes are just a few components of "heat" which we may think of as part of the "internal energy" of a body. Deformation addresses the fixed structure of a body. In general, elasticity starts with the presumption that the colliding bodies are immutable: they cannot change their internal state, so everything interesting about the collision can be observed externally, as properties of the entire bodies. This assumption fails as soon as the collision products have multiple internal states.
An inelastic microscopic collision involves the excitation of the internal degrees of freedom in one or both of the objects involved. My go to example is that the collision between two molecules can excite the vibrational modes of the molecules involved. Thus after the collision the net kinetic energy of the two molecules is lower than before they collided.
Dave
  • 4,203
For sound wave, a half of the wave is kinetic energy, and the other half is elastic potential energy. At each fixed position, the kinetic energy and potential energy are constantly converted from one to another. The potential energy is higher in the dense part of the sound wave, and lower in the dilute part.
For heat, it also composed of kinetic and potential energy, unless the system is simple as ideal gas composed of non-interacting mono-atom. For complex system. like solid or liquid, the heat is the oscillation of constituent lattice points, energy in form of potential and kinetic.
For electron magnetic wave, there are no masses, therefore there are no kinetic energy, but a field energy (energy density) in terms electric and magnetic field intensities.
ytlu
  • 4,354
What can happen to two molecules (or atoms, or smaller particles) colliding?
  1. They may separate internally unchanged, having just exchanged some momentum. This is called an elastic or adiabatic interaction.
  2. One or two of them may get excited in rotational or vibrational mode or a constituent particle (e.g. electron in a molecule) may change its state to a higher-energy one, leaving the initial particles with less kinetic energy. (the two variants are not really different when looked closer)
  3. The reverse may also happen - an excitation of one of the particles to be traded for kinetic energy.
  4. A constituent particle (an electron, an atom, a radical or some other particle) can get completely unbound and separate from the one of the initial particles.
  5. A constituent particle can be exchanged between the initial particles - e.g. two neutral molecules may become two ions when one electron moves from one to the other.
  6. An "interaction particle" (e.g. photon) can be radiated.
  7. Particles can fuse together, leaving a single, new, probably excited particle
Did I miss something?
... or any of the above 2..7 combined by whatever means.
fraxinus
  • 9,585
The problem is essentially one of definition.
At a macro level, the concept of kinetic (vs. say potential) energy is easy. As scale reduces, the definitions used in a classroom become harder and harder to maintain without propping up the definition by new clauses/criteria, redefining it, or abandoning it altogether.
This isnt entirely uncommon. Other macro properties and terms (pressure, volume, particle, colour, position, collision, elastic) also just fail us when scale reduces enough.
Essentially, when we cant average realistically, or take a higher level view of behaviour, the concepts that work at higher level dissolve.
The terms we use so freely, may simply not be applicable "as written and usually used" at those smaller scales.
So I would explain like this:
As scale shrinks, the concepts of "kinetic energy" as well as "collision" and "elastic" simply arent well enough defined to be helpful. And thats okay, they werent created to be.
Its the same as if you go to the doctor, and he wants to know if you have grown in the year (as a child), he doesnt want to be bothered with the height and angle of each hair, or whether one cell is higher than last time. (Pick your own better analogy!) He wants to know a big picture thing of it.
Similarly, yes we can try to probe each micro outcome, and match it to our higher level concepts. That'll maybe help for a while. But even those fail, as you scale down.
Ultimately the answer is.. .
...you cant answer this question, because you'd have to first rigorously define your terms. What counts as kinetic energy? Elastic? Collision? And make these valid at all scales you're asking the question.
Do that and fine. Mostly, we dont bother.
Stilez
  • 4,241
In an educational context, I think it's worth highlighting the concept of the domain of applicability of scientific models. Human intuition very often likes to operate via analogies to observed phenomena at the 'human scale' (i.e. macroscopic objects that we 'directly' perceive with our senses and have some evolved intuitive understanding of how they should behave [ignoring for the moment that sometimes these intuitions are quite wrong.]) When this intuitive sense is combined with a more rigorous mathematical modeling of these physical behaviors, it can then also be tempting to extend these same models via analogy to other domains.
This use of analogy can be fruitful in some cases, but it can also cause people to make bad predictions. When we say that a given mathematical model is valid, it's because we have experimental evidence that supports the model. In the case of classical mechanics, this evidence involves human-scale macroscopic objects. Early models of microscopic interactions attempted to apply these mechanics to the microscale (such as the Bohr model of the atom), but we've gathered enough evidence to be confident that classical mechanical models aren't a very good fit for the behaviors that frequently occur at that scale.
I think one of the most important things to learn in early scientific education is that we have models that can be used to make useful predictions, but that these models also have limitations and constraints. This domain of applicability is in turn defined by the accumulated experimental evidence showing both when the models work and when they do not. In my opinion, cultivating this mindset is an important part of developing scientific literacy, as it highlights the fact that it's not about our intuitive sense of what's going on, but rather the models we've built, the evidence we've collected and, in the context of sciences like Physics, the math underlying them.
While it is true that much of the KE lost by two bodies colliding inelastically is converted into KE of individual particles, not all of it is. More importantly, I recommend that you make a clear distinction between the macroscopic KE of the colliding bodies and the KE of the particles that comprise them and the environment with which they interact, otherwise you will raise more questions than you answer. If, for example, you conflate the translational KE of a football with the molecular KE of the air molecules within it, you will make it harder, not easier for students to figure out what is happening.
In practice, ordinary materials have a mesoscopic structure (fibers, connections between supra-atomic structures, arrangement of atomic planes). The inelasticity observed in macroscopic bodies, like balls bouncing, cars crashing, etc. involves that some work is done to changes irreversibly these mesoscopic structures. Different configurations of the microstructures involve different energies, so if you some all the kinetic energies before the impact and after it, you do not obtain the same number, because you are missing the interaction energy between mesostructures.
Davius
  • 1,700
Even at a grade-12 level, the answer is "no." It's perfectly reasonable to construct a collision where energy is conserved, but kinetic energy is not conserved.
For an example you could build with standard lab equipment, imagine two objects (e.g. carts on a track, which are common lab equipment) which collide using some sort of a spring. Usually the function of the spring is to make the collisions more elastic, so you can demonstrate that momentum and energy are both conserved. During the collision, the spring gets compressed. But we usually define a collision as "a brief interaction" and we take all of the "during" stuff and sweep it under the rug.
Now imagine that your compressed spring is connected to some kind of a ratchet, so that it can compress freely but cannot uncompress unless you release some mechanism. If you build this in a reasonable way, you could absolutely make your collision of ratcheting springs "completely inelastic," where the two carts stick together. However, you can store a large fraction of the energy in the deformation energy of the spring. A compressed spring's energy is not internally kinetic.
What's more, you can get that stored energy back later, perhaps years later, by releasing the ratchet. The dynamics of an "explosion," where a system's stored internal energy is converted into the kinetic energy of some number of fragments, are exactly the time-reverse of a "completely inelastic collision."
This same analysis can apply to any inelastic collision where a substantial fraction of the energy is stored in the fields between the interacting particles. For instance, in the famous Homestake Experiment, solar neutrinos drove the endothermic reaction
$$ \rm \nu_e + {}^{37}Cl \to {}^{37}Ar + e^- $$
The argon nucleus holds on to the energy from this inelastic collision for about a month, after which the inverse process (electron capture) happens spontaneously.
rob
  • 96,301
