Consider an ordinary differential equation (ODE) of a 1D damped oscillator of the form
$$\ddot{x}+\gamma\dot{x}+\omega^2x=0.~~(\omega^2,\gamma>0)$$
I want to know if this ODE is reversible i.e., given the information at present i.e. $x(0)=x_0$ and $\dot{x}(0)=v_0$, I want to know whether we can reconstruct the past uniquely. If yes, I would like to see how. I think one needs to make the change $t\to -t$ in the original ODE and then solve for $x(t)$ to predict the past.
If not, I would like to understand why. The answer here by Vincent Fraticelli suggests to me that the time-reversed solution uniquely predicts the past. But I may be wrong.
I )
$$ {\frac {d^{2}}{d{t}^{2}}}x \left( t \right) +{\gamma}\,{\frac {d}{dt}} x \left( t \right) +{\omega}^{2}x \left( t \right)=0\tag 1 $$
you can solve this differential equation and obtain the solution $x(t)$ and $x(t\mapsto -t)$
II )
for $~\tau=-t~$ from equation (1) you obtain:
$${\frac {d^{2}}{d{\tau}^{2}}}x \left( \tau \right) -{\gamma}\,{\frac {d }{d\tau}}x \left( \tau \right) +{\omega}^{2}x \left( \tau \right) $$
if the ODE is reversible the solution $~x(\tau)~$ must be equal to $x(-t)$ , this is the case if the initial velocity $\dot x(0)=0~$ equal zero, in this case is the ODE reversible!!
Eli
  • 13,829
One can solve this equation exactly and obtain the values of $x,v$ at any past moment... unless we are at the special point $x=v=0$. But this is not what we call reversibility of fundamental laws, since damping here is a phenomenological force.
Roger V.
  • 68,984
