I want a different proof of 6 degrees of freedom of a solid object made of $N$ particles. I am thinking along these lines:
The definition of rigid body is
$$\left\lvert \vec{r_i}-\vec{r_j} \right\rvert = \text{constant} \ \forall\ i,j \, .$$
This gives me $^NC_2$ constraints. There exist in total $3N$ equations, so the number of free variables should be $$n= 3N - \ ^NC_2=\frac{N(5-N)}{2}$$ which is clearly not the answer as $n$ is $N$ dependent, but it should be $6$.
I want to show that
$$\text{number of constraints actually required} = 3N - 6$$
which is the correct answer since I know $n=6$.
I am aware of the proof given in Goldstein, Rana Joag etc. I am asking is how to do it following this approach.
DanielSank
  • 25,766
Man
  • 1,398
You're imposing too many constraints. Suppose you have $N=4$ particles. These have $3N=12$ positions, and $N(N-1)/2=6$ constraints, forming a tetrahedron. Thus you have $12-6=6$ degrees of freedom, as expected.
Now add a fifth particle. This adds three more positions, but it is sufficient to put only three constraints on them, e.g. $|\vec{r}_5 - \vec{r}_1|$, $|\vec{r}_5 - \vec{r}_2|$, and $|\vec{r}_5 - \vec{r}_3|$. This will determine the position of particle 5 with respect to 1, 2, and 3, forming another tetrahedron. But it will also automatically determine the position of particle 5 with respect to particle 4.
In other words, for every new particle you need to add three new constraints, so that the number of degrees of freedom remains 6.
Pulsar
  • 14,970
