I know that the efficiency of a Carnot engine is given by $1-T_c/T_h$. This tells us that even with an idealized cycle, we can never have a 100% efficient heat engine unless $T_c$ is $0\,\text{K}$ or $T_h\to\infty$. I'm having a bit of trouble trying to understand this intuitively.
Perhaps my understanding of efficiency in this context is wrong, but it seems to me that if all of the heat supplied by the hot source is converted into work in an idealized reversible process, such that the final temperature is that of the cold sink ($T_c$), then this would be a 100% efficient process since there is no "waste heat" expelled.
I know that it is not possible in practice to convert all of the heat into work, but I guess my question is why, even if this were possible, would the engine still not be 100% efficient according to the Carnot efficiency?
dbp1023
  • 61
It is theoretically possible to convert heat completely into work (100% efficiency) in a process. That is what happens in the reversible isothermal (constant temperature) ideal gas expansion process in a Carnot Cycle. That does not violate the second law. But it is not possible to completely convert heat into work in a cycle. That would violate the Kelvin-Planck statement second law which states:
No heat engine can operate in a cycle while transferring heat with a single heat reservoir.
but it seems to me that if all of the heat supplied by the hot source is converted into work in an idealised reversible process, such that the final temperature is that of the cold sink ($T_c$), then this would be a 100% efficient process since there is no "waste heat" expelled.
It's not clear (at least to me) what "final temperature" you are referring to, but from the first law
$$\Delta U=Q-W$$
Then, in order for all the heat to be converted to work in a process, $Q=W$ and thus $\Delta U=0$. For an ideal gas $\Delta U=0$ only if the temperature of the system is constant (a reversible isothermal expansion as discussed above).
Because the Carnot efficiency only applies to a heat engine operating in a cycle. It does not apply to an engine for a single process which, as indicated above, can theoretically be 100% efficient.
Hope this helps.
Bob D
  • 81,786
From an intuitive perspective, when you introduce a hot fluid into a heat engine, that hot fluid contains a lot of thermal energy. To obtain 100% efficiency from that hot fluid, you would have to extract ALL of the energy out of it and turn that energy into work, based on the definition of 100% efficiency, which necessarily means that you would have to exhaust that fluid to a 0 K cold sink. Obviously, this isn't possible, as no working fluid can be driven to 0 K in a finite number of steps.
David White
  • 12,602
I am not too sure what you mean in your second paragraph. However, why we can't have heat engines with efficiencies of 100% can be understood as follows
First, we need to consider the second law of thermodynamics
`The entropy of the universe increases in the course of any spontaneous change'.
With a heat engine, we need to think about the system and its surroundings. If we remove the cold sink from our heat engine and assume that all of the heat extracted from the hot source is converted into work, then the entire change in entropy is $dS=-dq_{\text{hot}}/T_{\text{hot}}<0$, which is a violation of the second law, where $dq_{\text{hot}}$ is the heat extracted and $T_{\text{hot}}$ is the temperature of the hot source. If we now include the cold sink, the change in entropy becomes $dS=-dq_{\text{hot}}/T_{\text{hot}}+dq_{\text{cold}}/T_{\text{cold}}$ and considering the second law must be $dS>0$, and the energy avaiable for work is $dW=dq_{\text{hot}}-dq_{\text{cold}}$. For a change in entropy to be positive, the minimum amount of heat that must be discarded into the cold sink must be such that $dq_{\text{hot}}/T_{\text{hot}}=dq_{\text{cold}}/T_{\text{cold}}$, which gives for the work $dW=dq_{\text{hot}}\left(1-T_{\text{cold}}/T_{\text{hot}}\right)$, which gives for the efficiency of the conversion $\epsilon=\left(1-T_{\text{cold}}/T_{\text{hot}}\right)$, which is Carnot's formula.
To conclude, for there to be an increase in entropy, our heat engine must have a cold sink where some heat can be discarded to provide a positive contribution to the total change in entropy. We can think of this as a sort of energy tax that the universe takes when converting one form of energy to another. And since we can not find a cold sink at absolute zero from the third law, we can not have an efficiency of 100%.
jamie1989
  • 1,846
An isothermal process converts heat into work at 100%. It starts at $T_h$ and ends at $T_h$. If that process is reversed at $T_h$, it requires the same amount of work put back in. The work for the cycle is zero.
If done at a lower temperature, less work is put back in. It requires heat rejection to maintain that lower temperature. The cycle has a net work output.
It requires zero work at zero Kelvin. That temperature is required for a 100% cycle. It requires zero heat rejection at zero Kelvin.
Eric
