Suppose we have a rigid token-ring network. An observer at any node can seemingly determine the angular momentum of the network by measuring the time it takes for a packet to travel around the ring in each of the two directions. Is it possible by any means for an observer to determine whether the network is knotted?
Actually, an observer can't measure even the angular momentum. For example, suppose the token ring is in the form of a figure 8. Then the times around the two directions are identical even if the token ring is rotating.
Carl Brannen
  • 13,059
-1
Measure electric field. This gives you position of electron. And complete topology of wire.
TROLLHUNTER
  • 5,341
