Let me provide some insight, I was studiying about General Relativity, and I read that it "encapsulates" Newtonian Gravity. I understand this perfectly, because, Einstein used lots of ideas form Newton's Laws of Motion for this theory. The thing is, if it "encapsulates" Newtons Laws, suchs as: $$ F = m\vec{a} $$ $$ F = G \frac{Mm}{r^2}\hat{r} $$ $$ \nabla \cdot g = -4 \pi G \rho $$
Yes, you have this: $$ \frac{d^2 \vec{x}}{d \tau^2} = -\large \Gamma_{\normalsize \mu \nu}^{\normalsize \alpha} \normalsize \frac{d\vec{x^{\mu}}}{d \tau} \frac{d\vec{x^{ \nu}}}{d \tau} $$
But this equations takes in accounts Relativistic Effects, like time dilatation, redshift, space contraction... and also is common for all Space-Time metrics such us the Minkowski Metric, the Schwarzschild Metric among others.
But would it be possible to derive the corrected Newton's Laws (the same way you get Maxwell's Equations from Quantum Mechanics) if you don't take in account Relaivistic effects, like time dilatation and space contration when you travel at speeds near $c$, or the rotation of a body (like in the Kerr Metric), etc. This would correct Newton's Laws and also give more precise descriptions of orbits and movements in which gravity is involved (like with the preccesion of Mercury's Orbit) without the needs of using complex maths like differential Geometry or Tensor Calculus.
Is this possible? If possible, how you derive the corrected Laws?
Correct me if I'm wrong.
EDIT: I'm not looking for obtaining the exact same equations form Newton's Laws of gravity with General Relativity. I'm asking for a way of deriving the Newton's Laws which will explain things like the precession of Mercury but at the same time you are not travelling near $c$ so you don't have to bother about Special Relativity effects; only General Relativity ones.
