Inside the Sun there has to be a net current giving rise to the Sun's magnetic field. Because the Sun orbits the core of the Milky Way with considerable speed (about 0.1% the speed of light) the charges in the Sun's electric current will experience a Lorenz force. On top of that has the Sun a small residual charge (lost electrons). Currents and charges experience a force in the magnetic field of the Milky Way. The current in the direction of motion will be greater than the current in the opposite direction giving a net force.
How big will the net Lorenz force due to the currents and net charge be?
The effects of the galactic magnetic field on the net charge of the Sun aren't too hard to calculate:
  • The magnetic field for a spiral galaxy is about 1 nT.
  • The net charge of the Sun is on the order of 80 C.
  • The speed of the sun is about 0.1% of $c$, which is about $3 \times 10^5$ m/s.
Plugging these in to the standard $F = qvB$ equation, we get a total force of about 0.024 N on the Sun. For comparison, an Earth-like planet in the Andromeda Galaxy would exert a force of about 1.4 N on the Sun, or about 60 times larger than this effect.
The effects of the currents within the sun are probably well-approximated by treating it as a dipole. The magnetic field of a dipole at a distance $R$ is on the order of $B_\text{dip} = \mu_0 M/R^3$, while the magnetic force on a dipole due to an external field is on the order of $F = (\vec{M} \cdot \vec{\nabla}) \vec{B}_\text{ext} \approx M B_\text{ext}/\ell$, where $\ell$ is the typical length scale of the variation of the external field. Combining all of these, we have $$ F \approx \frac{B_\text{ext}}{\ell} \frac{B_\text{dip} R^3}{\mu_0} = \frac{R}{\ell} \left( \frac{B_\text{ext} B_\text{dip} R^2}{\mu_0} \right) $$ We can get the order of magnitude by noting that the Sun's magnetic field at the edge of its photosphere is about 400 µT (from Wikipedia); and plugging in the numbers, with $R$ as the solar radius, the above equation becomes $$ F \approx \frac{R}{\ell} \cdot (1.5 \times 10^{11} \text{ N}). $$ The question is then how large $\ell$ is, i.e., on what length scales the galactic magnetic field varies. If $\ell$ is itself about the radius of the galaxy, then $R/\ell \approx 1.5 \times 10^{-12}$, and you end up with a result that's comparable to the Lorentz force on the Sun's charge. It seems likely, though, that local effects might decrease the scale of variation by a couple of orders of magntiude, leading to a force that would be on the order of a few tens or hundreds of newtons rather than a few tenths of newtons. All in all, though, we should not expect either force to be very large at all.
