-2
Let's say I were to have made a train that travels at $60$ $mph$. Let's also say that I have another train inside of the first train that is also moving at $60$ $mph$ in the same direction. So from an observer standing outside of both trains, the interior train would be moving at $120$ $mph$ whereas the exterior train would be moving at $60$ $mph$. Theoretically, would you be able to have multiple trains moving inside one another eventually reaching the speed of light?
Kuplar
The velocity addition you have done pertains primarily to Newtonian mechanics. In special Relativity, we use a different velocity addition formula
$u = \frac{u'+v'}{1+\frac{u' v'}{c^2}}$
Here you can see that if there exists a train travelling at speed of light $0.8c$ and then shoots particle at 0.8c, Galilean velocity addition would give you $1.6c$ whereas the above formula would give you $0.97c$. This condition has arrived because no particle can travel faster than the speed of light. The speed of light being the speed limit is a primary postulate of Special relativity.
joseph h
  • 31,821
