The other day, a friend of mine asked me this question:
If you had a sphere in the dead of space which contained a vacuum and through some mechanism began expanding that sphere with outward force uniformly in all directions across its outer surface, what would happen inside the sphere?
My initial thought was the sphere would expand at a rate corresponding to the elasticity of the spheres material, until it would eventually break. Until it does break, the vacuum would continue to exist with an increasing volume of vacuum. Nothing more would happen.
But is this correct? My intuition is that if there is "nothing" in the sphere to begin with, then there will be a larger volume of "nothing" as it expands. Can there really be "more" of a vacuum?
Take a look at the force diagram. If the vacuum inside and outside is "pure," i.e. no particles at all, then there's nothing restraining the expansion other than the material of the sphere itself.
If you take "real" space, the vacuum contains on the order of one atom or particle per cubic cm (depending on location in space and the source quoted, this can differ by an order of magnitude). So now, given the rough temperature of 10 K, you can calculate the pressure-temperature-volume relationships using the same formulas as we use for Terran atmospheric statistical mechanics.
And as some wag commented, if you pull fast enough, quantum pair-formation might occur.
Carl Witthoft
  • 11,106
