In Electrodynamics the law of induction for a moving integration contour (not necessarily a conducting wire) is, according to my books, e.g. Jackson, Classical Electrodynamics
$\oint_C \vec E' \cdot d \vec l = -\frac{d}{dt}\int_S \vec B \cdot \vec n da$
Here, notably, $\vec E' = \vec E + \vec v \times \vec B$ is the field in the rest system of the element $dl$
Just to mention, this approach is taken also in the Wikipedia article.
With the relation
$\frac{d}{dt}\int_S \vec B \cdot \vec n da = \int_S \frac{\partial }{\partial t} \vec B \cdot \vec n da + \oint (\vec B \times \vec v)\cdot d \vec l $
this is consistent with the well known Maxwell Eqation
$\vec \nabla \times \vec E = -\frac{\partial \vec B}{\partial t}$
Now, there is a book which I dont't want to mention in detail, where the law of induction is stated like
$\oint_C \vec E \cdot d \vec l = -\frac{d}{dt}\int_S \vec B \cdot \vec n da$
taking E as the field in the laboratory frame. By combining this with the same vector identity above they derive a new equation
$\vec \nabla \times \vec E = -\frac{\partial \vec B}{\partial t}+\vec \nabla \times (\vec v \times \vec B) $
The author says: The first two terms are identical to Maxwell's equation, the third term is due the Lorentz force.
Now, w.t.f. is this? The equation doesn't give any sense for me, because how can the relation between B and E depend on some velocity of an imaginary integration contour??? However, the author insists, that this equation is a "better" generalization of Maxwell's equation and that this was argued also by Richard.P. Feynman in his Lectures, Volume II. Looking into this book I cannot find anything like this...
I'm quite confused now...
MichaelW
  • 1,511
To me, Maxwell's equations are synonymous with the work of god, so much so that I'll even take these equations as definitions for the fields. So, what I call the electric and magnetic fields are respectively the two vector fields $\mathbf{E}$ and $\mathbf{B}$ which (in the presence of charges and currents $\rho,\mathbf{J}$) satisfy
  • $\nabla \cdot \mathbf{E}=\dfrac{\rho}{\epsilon_0}$
  • $\nabla\cdot{\mathbf{B}}=0$
  • $\nabla \times \mathbf{E}=-\dfrac{\partial \mathbf{B}}{\partial t}$
  • $\nabla \times \mathbf{B}=\mu_0\mathbf{J}+\mu_0\epsilon_0\dfrac{\partial \mathbf{E}}{\partial t}$
To me calling anything other than these two fields to be electric/magnetic field is just weird. Also the third equation is what I always refer to as "Faraday's Law". Once we have agreed on this terminology for what the electric and magnetic fields are, then the rest is a simple matter of calculus, there's no more physics involved. More precisely, we have the following theorem:
Let $\Sigma\subset \Bbb{R}^3$ be a compact, oriented, smooth two-dimensional manifold with boundary (i.e a nice surface for which Stokes' theorem is valid). Let $t\mapsto \psi_t$ be a one-parameter group of diffeomorphisms with infinitesimal generator $\mathbf{v}$ (i.e for every $p\in\Bbb{R}^3$, we define $\mathbf{v}(p):=\frac{d}{dt}|_{t=0}\psi_t(p)$). For notational purposes, denote $\Sigma_t:= \psi_t[\Sigma]$. For ANY smooth vector field $\mathbf{B}$, define its time-varying flux relative to the family of surfaces $\Sigma_t$ as \begin{align} \Phi_{\mathbf{B}}(t):=\int_{\Sigma_t}\mathbf{B}(\mathbf{r},t)\cdot \mathbf{n}(\mathbf{r},t)\,da \end{align} Then, (using Leibniz's integral rule for differentiating under the integral sign and Stokes theorem) \begin{align} \Phi_{\mathbf{B}}'(t)&=\int_{\partial\Sigma_t}-(\mathbf{v}\times \mathbf{B})\cdot\, d\mathbf{l} + \int_{\Sigma_t}\frac{\partial \mathbf{B}}{\partial t}\cdot\mathbf{n}\,da + \int_{\Sigma_t}(\nabla \cdot \mathbf{B})\,\mathbf{v}\cdot \mathbf{n}\,da \end{align}
Thus far, this is a purely mathematical result, with zero appeal to any physics.
Now if we appeal to physics (or rather just some basic terminology established in the first paragraph on what constitutes as an electric/magnetic field) then we find that by taking $\mathbf{E}$ and $\mathbf{B}$ to satisfy Maxwell's equations, the second term on the RHS becomes the curl of $\mathbf{E}$ which can be transformed via Stokes' theorem. The third term vanishes. Therefore, we obtain \begin{align} \Phi_{\mathbf{B}}'(t)&=-\int_{\partial\Sigma_t}\left((\mathbf{v}\times \mathbf{B}) + \mathbf{E}\right)\cdot d\mathbf{l}. \end{align}
At this point, we can define the integral on the RHS as the EMF in the loop $\partial \Sigma_t$, so that the integral form of Faradays law reads "the rate of change of magnetic flux through a surface is minus the EMF in the loop enclosing the surface" (with all the appropriate caveats regarding orientation).
Also you haven't explained why the author claims your proposed equation is a "better generalization" of Maxwell's equations. In any case, I would find this pretty weird because first of all, the last equation you wrote is not a generalization; to me it just looks like a confusing re-definition. Also, I took a brief look at Feynman's book and I don't see anything which says that Maxwell's equations aren't general enough.
peek-a-boo
  • 8,367
